Local Time 08:10 25 Oct 2026 Privacy Policy
Forum Index : Electronics : New MPPT Board Design
sjh7132
Posted: 06:19pm 31 Dec 2011
Is there a good way to post a youtube video?
MPPT Video
Steve
Posted: 12:26am 01 Jan 2012
Adding a link like you have done is probably the best way.
Thats a very interesting video there Steve, well done. Keep us posted on how your MPPT development goes.
govertical
Posted: 11:12am 01 Jan 2012
Hi, if you use a battery for a test load do need a special interface or do you limit the board output ?
just because your a GURU or forum administer does not mean your always correct :)
sjh7132
Posted: 04:43pm 01 Jan 2012
  govertical said   Hi, if you use a battery for a test load do need a special interface or do you limit the board output ?
Like I said in the video, right now the firmware is pretty crude, but eventually I want to have all the limits configurable so you could tell the board that to charge hard as long as the output voltage is below 14, and then start cutting back on the current so that it's zero if the battery is at 14.5
There is also a dump load circuit on the board so that if your battery can't take the power, it can put it into a dump load to keep the turbine under control.
Steve
