Local Time 08:22 25 Oct 2026 Privacy Policy
Forum Index : Electronics : ETI 131 Power Supply
jebz
Posted: 10:54am 09 Dec 2011
Does anyone have an electronic copy of the documentation for the ETI 131 lab power supply?
larny
Posted: 01:33am 16 Dec 2011
Sparkey contacted me via another site (since he is banned from this one) & asked me to post this info for you.
(2011-12-16_113150_ETI131_a.zip
2011-12-16_113321_ETI1311_b.zip
Edited by larny 2011-12-17
jebz
Posted: 02:35am 17 Dec 2011
  larny said   Sparkey contacted me via another site & asked me to post this info for you.
Thankyou Sparkey and Larny. I've been to Ken's site but not registered yet. I've rescued a badly maintained ETI131 that needs repair. On the outside it's good but the transformer has been removed and some other components were missing. Considering many projects consume most of the cash on the hardware items that are still good, it should be a good unit once repaired.
larny
Posted: 04:44am 19 Dec 2011
You're welcome.
Sparkey sent me another PM.
I quote
..please inform him that this is a split voltage unit ..IE: 20 volt or 40 volt he will have to make the difference due to components that are fitted...this is important and I would suggest fitting a bridge "rect" instead of the shotty diode config...his transformer will govern what voltage the unit produces..and this will mean he will have to look at what components are fitted to the pcb...generally its ..imop it is not a bad unit as the saying goes "the older sometimes ,,the better "..
Please register on Ken's site so you can communicate directly.
