Forum Index : Electronics : Synchronous Invertors.
| mrpackethead Newbie Joined: 11/11/2006 Location: New ZealandPosts: 17 |
Anyone got a design for a inverter that will act synchronously.. ( ie you can parrallel them together ). Needs to be pure sine wave as well. Can't have a control bus between the inverters either.. Every thing should be as simple as possible. Not simpler. |
I think you would be lucky to get such a circuit off the internet. I've searched before and all I can find are circuits for modified sine wave inverters, no sync option, and usually use large modified transformers. Good luck hunting. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| RossW Guru Joined: 25/02/2006 Location: AustraliaPosts: 495 |
The only thing I can think of that would do what you're talking about would have to assume you are a man of nearly unlimited wealth. If you came to me with a large wad of cash, and this problem, I'd point you at grid-tie inverters with anti-islanding. These guys will take your DC and convert to AC, nice sinewave, and will phase-sync and voltage-sync, to what they consider to be "the mains" I understand that when they come on-line, they monitor the supply, synchronise themselves and then enable their output. They then continuously monitor the "grid" to check they remain in phase. Expensive, but might give you something to think about. RossW |
Alas, i am not a man of unlimited wealth. Yes, i've been looking at grid tie inverters and actually have a small one on my desk, that i'm now contemplating trying to reverse engineer.. I've found some thesis's published on grid tie applications, and how to implement grid ties. Building an invertor that will product nice sine wave output is not so hard. Its not that different from an audio amplifier. Whats tricky is making them run efficently. If you are happy with 30% efficency its a peice of cake. I'm looking for 85%+!! There are plenty of DC/DC inverters that will run in parallel, DC/AC is a new challenge for me.. I'm sure its doable, ( well it is ), and i'm just going to have to go and find out how to do it. Every thing should be as simple as possible. Not simpler. |
| Megawatt Man Senior Member Joined: 03/05/2006 Location: AustraliaPosts: 119 |
Have a look at this. http://www.edn.com/article/CA419572.html I don't understand it all, particularly the seemingly high source voltage, and the "to the other inverter" text. There are 2 reasons for which circuits are not readily available 1. perceived legislative consequences and 2. commercial reasons - there are sites from whom you can buy the details. A few years ago the UNI of NSW developed a 1 kW solar pane with an integrated synchronised sine wave inverter. You stuck it on the roof and had a sparkie connect it to your switchboard, after arranging with you electricity supplier to buy an electronic two way meter. They sold it to a SA manufacturer from whom you now buy the package, so you can be sure that the design details are commercial-in-confidence. Megawatt Man |
I will solve this problem. I've now figured out how to control the power output of an invertor, effectively allowing me to run a MPPT.. I'm only looking to build a small unit.. Perhaps in the order of 500-1000W.. But have multiple of them around the place. Every thing should be as simple as possible. Not simpler. |
