Local Time 19:04 24 Oct 2026 Privacy Policy
Forum Index : Electronics : New Oatley Regulator + new 7p2p rotor
brett
Posted: 03:35am 20 Nov 2006
I am good with building not good with electronics.
My windmill will have the 7p2p wiring and was thinking of using the new Oatley controller.
Will this controller handle the watts / amps produced from a windmill built exactly like on Glen's web site?
And does this negate the need for a load to dump current into when the battery bank is charged?
The new controler seems to be only set up for 3phase input not seven phase. Is this a problem?
Just out of interest can some one give me a "rough" typical output (amps/hr) from these windmills, charging a 12v battery bank. I understand each mill is different but a guide will be helpful.
Pt w/field Matt
Posted: 12:57am 28 Nov 2006
hi brett im doing one of those regs now and because im running 7 phrase like you ive decided to use 4 35 amp bridge reterifers to run up the tower and send dc to the reg,you loose some volts but proberly picked up some through 7 phrase,just connect dc after the 12 diodes on the board
matt down south
Posted: 11:27am 28 Nov 2006
Hi Brett
As a guide for windmill output, my windmill is also a 7p2p on 12 volts and I get up to 5 amps most of the time in light winds. When the wind picks up it goes up to 10 amps pretty easy and I've see close to 20 amps during the real strong gusts. Its charges a couple of car batteries, and I use these to power a string of garden lights at night. The lights draw about 1.5 amps all night, next day the wind starts up at about 9am and by midday I notice the charge controller has switched the windmill over to load, meaning the windmill only needs a couple of hours to recharge the batteries.
