Local Time 07:30 25 Oct 2026 Privacy Policy
Forum Index : Electronics : my mills weeklink
shawn
Posted: 09:28am 28 Feb 2011
Found the weeklink in my system my caps let out the magic fluid
I do live in a high wind zone and it realy hammers my mill
I run two 330uf 400v caps per phase before the rectifires one stattor was a 80 in half delta this cut in first and worked the hardest cooking my caps
I know nothing of how these work but understand i need bigger caps can anybody help???
VK4AYQ
Posted: 10:27am 28 Feb 2011
Hi Shawn
If as you say you live in a high wind zone why are you using caps? They are for boosting the low end in low winds but if you have good wind they are only another thing to go wrong, you may consider using the boost module i have on my new mill as it does away with the need for caps, but if good wind was around I wouldn't use either.
All the best
Bob
Foolin Around
Janne
Posted: 03:39pm 01 Mar 2011
That's the inherit problem with electrolytic caps, sooner or later they're bound to fail.
For this usage, the only certain way would be to use motor run caps. Motor starter caps are also suspect in this usage, as they're not designed to run at 100% duty cycle.
The drawback with run caps is that they're big and expensive.
My projects
shawn
Posted: 07:05am 02 Mar 2011
Thanks for the responce guys when i first built this set up i read gordans cap mods
may have read them wrong!
anyway have removed them from the offending stattor and all going strong again had some 130 km winds here today and i made some good power bank is full so happy once more.
