Forum Index : Electronics : Cheap PIC/PICAXE development board
| vasi Guru Joined: 23/03/2007 Location: RomaniaPosts: 1697 |
Hi guys, Cheap PIC/PICAXE development board in the Arduino factory form. See it here. ![]() Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
Thats pretty cheap! Thanks for the link Vasi. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Janne Senior Member Joined: 20/06/2008 Location: FinlandPosts: 121 |
"The kit comes with everything you see above" "PIC or PICAXE not included" I think the picture clearly shows having a pic / picaxe plugged in. If at first you don't succeed, try again. My projects |
I think he wanted to say "bellow" ...
I think that what is working with a PICAXE can work also with a raw PIC - I mean, if you use two or three resistors for serial comm connection, then you can use the same for PIC. So, it can exclude the RS232 chip (if that is what he use) and we can get the board even cheaper. Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
