Local Time 07:21 25 Oct 2026 Privacy Policy
Forum Index : Electronics : USB Data Logger in SC Magazine
Posted: 12:29pm 25 Nov 2010
Picked up the December 2010 issue of Silicon Chip magazine today. There's a new project that might be of interest, a data logger that records to a memory card, and can be powered with a couple of AAA batteries.
It can store up to 32GB of data onto a memory card ( MMC, SD, SDHC ), and draws a couple of mA, so will run on batteries for weeks. It has a USB port to transfer data with a PC. There are 6 digital and 4 analogue inputs, and real time clock.
Its a multipart project, this month was just a introduction to its features. If its cheap enough, it might make a fantastic windmill/solar logger for remote locations, or in situations where you dont want to run a PC 24/7 to record the data.
Will keep an eye on it.
Posted: 02:57pm 25 Nov 2010
Sounds very interesting, do it say what the processor is? (pic, picaxe, atmel)
Looked at the Mag on a counter today but that was all, didn't pick it up for a scan through
Pete.
Posted: 09:56pm 25 Nov 2010
Its a Pic Pete. Pre-programmed I guess, it sounds like it has support for its own scripting language. You can put a script onto the SD card, to control how the logger will behave. Very interresting.
vasi
Posted: 08:07pm 09 Dec 2010
  Gizmo said  It can store up to 32GB of data onto a memory card ( MMC, SD, SDHC ), and draws a couple of mA, so will run on batteries for weeks. It has a USB port to transfer data with a PC. There are 6 digital and 4 analogue inputs, and real time clock.Glenn
It use 32bit FAT or it use direct access to memory card via SPI interface. I think is the last variant if it needs to send the memory card content to the PC through USB cable. If this is the only way of sending data to PC, then I suppose the memory card can't be read by PC in a normal way...
We have in JAL a MMC/SD card library but we don't have an usable "Append" function (yet) .
Elvish name: Mablung Miriel
Beyound Arduino Lang
vasi
Posted: 08:17pm 09 Dec 2010
  Gizmo said   Its a Pic Pete. Pre-programmed I guess, it sounds like it has support for its own scripting language. You can put a script onto the SD card, to control how the logger will behave. Very interresting.
Then it have a normal FAT file system and the PIC is bigger than 18F2550/4550... I'm afraid is a 3.3V system?
