Forum Index : Electronics : data logger
ProTow![]() Newbie Joined: 03/09/2010 Location: United StatesPosts: 29 |
anyone know of where to get a complete datalogger at? for getting data on wind speed? or a cheap way to get a Davis wizard III (3) to work without buying "davis" data logger? If it works the First time You did something Wrong. |
Hi ProTom Have you seen the PicLog page? http://www.thebackshed.com/windmill/PicLog.asp The latest version of the software is pretty solid, and I'm releasing a updated graphing component this weekend. If you dont want to build your own circuit, have a chat to Pete ( Downwind ), he has put together a Power Logger unit that works with the PicLog. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Hmmmm that looks Good... Thanks Glenn If it works the First time You did something Wrong. |
