Local Time 07:03 25 Oct 2026 Privacy Policy
Forum Index : Electronics : 200A hall sensors
graynomad
Posted: 01:45am 29 Jul 2010
Just found these.
http://uk.farnell.com/allegro-microsystems/acs758ecb-200b-pf f-t/current-sensor-200a-3cb/dp/1791391
200Amp Hall effect current sensor chips. Great for those DC battery bank monitoring widgets. How you actually connect some 95mm2 cable to them though I'm not sure.Edited by graynomad 2010-07-30
Rob Gray, AKA the Graynomad, www.robgray.com
VK4AYQ
Posted: 03:21am 29 Jul 2010
Hi There
It looks like it clips on but on that size wire a dob of glue to hold it in place.
Cant get the data sheet to download from the site so will try another search for data sheet.
All the best
Bob
Foolin Around
graynomad
Posted: 03:35am 29 Jul 2010
This is the link,
http://www.allegromicro.com/en/Products/Part_Numbers/0758/07 58.pdf
it just worked for me.
Otherwise try
http://www.alldatasheet.com/view.jsp?Searchword=ACS758
I guess the trouble with wires that big is that it's more mechanics than electronics, you'd have to be very careful to affix the lugs to something solid then run wires (bus bars really) to the sensor.
But what I think could be the good thing about these is that they cost about $15, that's better that a 200A shunt.
RobEdited by graynomad 2010-07-30
VK4AYQ
Posted: 01:21pm 29 Jul 2010
Hi Rob
Thanks for that I did manage to download it this time.
All the best
Bob
Foolin Around
Posted: 02:08pm 29 Jul 2010
A few members here have used the allegros for some time now but they can be very noisy on their output.
Pete.
