Local Time 17:45 24 Oct 2026 Privacy Policy
Forum Index : Electronics : Backup Genset Fun
Bryan1
Posted: 06:04am 20 Jun 2026
G'Day Guy's,
           Well this 80 amp Staff&Stanbury solid state battery charger has claimed a few gensets to date, now a few years ago bought a 7.7KVA genset from Paramount Browns where it did work for a couple of years then onday it just decided to stop outputting 240 volts AC. So went back in only to be told they don't sell spare parts so I bought a 4KA genset which did work fine with the charger.
Now after I put in that 1.9Kw solar array running the genset became a thing of the past where we didn't use the genset for well over a year. Now after several dull days the genset was needed and when I started that 4KVA genset found it wouldn't run with the 13 amp load so I had to drag down my 20 year old Honda genset from my shed where that has just worked ever since until recently.
So decided to have a look at this 7.7KVA genset and the first thing was getting rid of the old fuel. Now I did see this hack where if one drills a hole in the bottom of a 2 litre bottle of coke and put in a tube then seal it with hot melt glue, put the tube in the fuel tank squeeze the bottle and out comes the fuel   Got 99% out and put some fresh fuel in and got the engine running but silly me had the fuel turned off.
When I tried again with the pull start the cord broke so had to go in and buy some starter cord to reset the pull starter. Got it fired up and found with a new regulator I did manage to buy after talking with the boss the genset was only outputting 4volts AC, I put my DMM on DC volts and found the brush's were outputting 5 volts.
Rang the boss and asked him what else could be wrong and he said the brush's could be the problem, now if the are outputting 5 volts they are connected so it does look like the engine of this genset is going to be a donor for my 6" Jaw Crusher.
Now as the Honda genst kept cutting out this morning went and bought a new spark plug  and the genset run until the house battery was fully charged
So it does seem the old stuff just continues to work where this newer stuff just lasts for the warranty period.
Regards Bryan
Godoh
Posted: 06:12am 20 Jun 2026
Hi Bryan , it sounds like the genset may have lost its residual magnetism.
The ancient dunlite generators have the brush gear accessible so that one can take the insulating caps off, and put a 9 volt battery straight onto the brushes to excite the alternator. And away they went.
Different types of alternators will need a different system. But if you got a 12 volt battery and put some leads on it and put one on each rotor brush or on each slipring then it may just decide to work.
I don't have a 240 volt gen set any more. Once every few years we live inside the clouds and if that goes on for more than 3 days I need to charge the batteries as I don't like them going below 70% charge.
So I have a 5 hp petrol motor and a car alternator. I use a rheostat to control the field current. No regulator, just power straight to the field coils. And usually set the alternator current to around 50 amps. As I say it only gets used once ever 3 or 4 years for a couple of hours, so no need for anything flash, but it works great.
Godoh
Posted: 06:18am 20 Jun 2026
I forgot to mention Bryan that you only need to connect the 12 volt power to the field coils for a very short time, just a few seconds is enough to remagnetise the fields
Pete
Bryan1
Posted: 06:22am 20 Jun 2026
Pete I did flash a 12 volt battery across the brush's and it made no difference and after I take the gen head off the engine I do think I will find the cause.
This Honda genset has eaten several run caps and replacing the cap with a new one got it working again so it can live on doing it's job
Now the engine for a 7.7KVA genset would be around 15HP so with that powering my Jaw Crusher will crush quartz nice and easy and the best part if I don't find any gold the very small rocks do make good road base
I do want to get this Jaw Crusher project finished as I reckon I can sell it for around 10K to some gold hunting freak that has more money than sense
Regards Bryan
Posted: 08:41am 20 Jun 2026
Re the Honda, I have a very old one (3.6kW side valve engine, 1980ish model) that had similar symptoms a few decades ago. The very low output voltage turned out to be due to a partial short between the main winding and regulator/field supply winding.
This messed up the feedback voltage sensing, which is taken from a tap on the main winding.
The cure was a small isolating transformer to provide the feedback voltage.
Post the model number and I will try to find a circuit diagram. Perhaps a similar trick will work with yours.
Revlac
Posted: 09:02am 20 Jun 2026
  Quote  The ancient dunlite generators have the brush gear accessible so that one can take the insulating caps off, and put a 9 volt battery straight onto the brushes to excite the alternator. And away they went.
Yep that reminds me of the old Dunlite (think its 4Kva) with 13Hp B&S motor,
We did replace the high speed diode on the Back of the Brush plate, last time I ran it on gas so no longer have issues with stale fuel....Haven't used it for years, for Honda there are LPG Carburettors around makes it very easy to start but was never impressed with the mixture when the governor opened up, regulator might have been too small.
Anyway we moved on to the old Lister genset....never fail.
Don't use it now the solar powers the house so well.
late to the post, never mind.
Edited 2026-06-20 19:03 by Revlac
Cheers Aaron
Off The Grid
Bryan1
Posted: 09:21am 20 Jun 2026
Phill the 7.7KVA genset is a Paramount Browns model now all that genset did was supply 13 amps to the S&S battery charger and oneday it decided to stop working, now I did buy a new regulator for it and it didn't cure the problem. So as the engine is still good it will be a good exercise to convert the output to a V-pulley for my 6" Jaw Crusher.
That Honda 5KVA genset was bought in '05 and with it using a genuine Honda motor there are 3 things that stop it working usually. Air, fuel and spark as the auto start failed years ago and I did buy enough starter cord to redo the pull starter.
A few years ago it stopped working so bought that 7.7KVA and dragged the honda upto my shed, replaced the run cap and reflashed the stator and it served as my shed charger for years.
Now as that 4KVA was no good did a swap of gensets so I have a spare supply for the shed, now since that madboard is working it does everything I ask inculding keeping my tobacco seedlings warm.
Regards Bryan
Godoh
Posted: 12:17am 21 Jun 2026
Hi Bryan that Dunlite gene looks like it could do with a clean out and cleaning up the slip rings.
We used to repair lots of them, they are the ones that a 9 volt battery fits well onto the brush gear to excite them. The idea is to run the generator, put the 9 volt battery onto the brush terminals. ( I can't recall which is the positive one but I think it is the top one.)
Usually the generator will kick in and sound different when it starts to actually work. But the one in your photo looks like the slip rings are pretty filthy, I would clean them first. Maybe just taking the brushes out an using a piece of emery paper on a thin stick would work to clean them without disassembly.
Bryan1
Posted: 02:53am 21 Jun 2026
Pete that dunlite is Aarons not mine mate, anyway got the genset part off and dragged the genset frame with the engine on upto my shed and did a measure up on the Jaw Crusher and it's going to fit in nicely   now for mounting I do have 4 off flexible mounts and as the output shaft is tapered I will setup my toolroom lathe with the right angle and machine up a new mount so I can use a taperlock to mount the pulley.
Once I blue the taper and get 95% or better coverage when it's locked on it should drive nicely.
Now the motor is 16HP so plenty of power to crush rocks and the best part is spending the time getting this done as now I have my mig welder working off the inverter no more stick welding.
Pictures to come once I get the engine mounted in the frame as this project did start back in '06 so for it's 20 year birthday it can finally run as I intended all along.
Regards Bryan
Revlac
Posted: 04:43am 21 Jun 2026
Hi Bryan, most of the smaller direct couple gensets had tapered shaft and not even interchangeable at times, I like the rock crusher idea my OldMan started building one over 30 years ago, still have some parts I think, the Engineering workshop Next door used to make heaps of crushing jaws and get them heat treated/hardened
Keep us posted on your projects, sounds like fun.
Cheers Aaron
Off The Grid
Bryan1
Posted: 06:15am 21 Jun 2026
Well I have found out what the problem was one of the brush's had over heated and was missing so looks like I'm going to rebuild it and as I have it apart I will put a new bearing on the stator and give the commutator a good clean so when the new brush set arrives the genset should be working again
Anyway got the engine mounted in the Jaw Crusher frame
and the side view
So while I thought this was a good idea the engine is just a tad too large but as they say if you don't try you will never know
Regards Bryan
Bryan1
Posted: 03:52am 23 Jun 2026
Well yesterday afternoon got a call saying that new brush set was here so went and picked it up then this morning rebuilt the genset   now I do need a rattle gun to do up the central bolt and can't justify buying one just now and rang a mate who said he had one so when he gets here time to see if this genset works.
Anyway on another note those Induction Tester boards arrived yesterday too so had a bit of fun finding parts. Now my Sprint Layout skills are getting better learning what not to do as I had to drill some of the connections out to 1.7mm just to fit them. I was missing the dual diode so thought element 14 is a local company and they do have a base in Adelaide but no option for pickup and had to go over the mark they set for free shipping.
Looked at this morning's email from them due to ship on the 29th and coming from England   so much for a local company and lesson learnt not to bother with them again.
Regards Bryan
Revlac
Posted: 12:29pm 23 Jun 2026
The OldMan had built the large cam for the Jaw crusher and not sure what Flywheel we were intending to use but it needed to be fairly heavy to do the job, he used to feed one of those massive cone crushers at one of the mines, not sure which one, he worked for several, did drilling as well.
I have put them back together without a rattle gun as the bolt was often long and too springy for the rattle gun, I'm surprised you don't have at least one, we have several all the way up to 1 Inch drive, essential tool for working on the Excavator.
I have never ordered from E14 due to postage price, I have ordered from RS long time ago when they had free shipping soon after they started charging big and sometimes parts come from overseas, had to check where the stock was located before ordering, postage was often much more than the items ordered.
good luck with your build.
Cheers Aaron
Off The Grid
Bryan1
Posted: 12:16am 24 Jun 2026
Well Aaron decided just to give the 14mm spanner a few love taps and the genset started easily with the pull cord and the AC volt meter went straight to 240 volts
So time for a load test
Put both my old heating elements on flat out so 3 hot plates going which is around 3Kw as tested on my inverter.
So hooked up my mig and did a decent run @110 amps which according to my inverter is around 3 Kw and it ran perfect
So after a few years of non service this genset is going back on the house array for the backup generator.
Regards Bryan
Godoh
Posted: 01:46am 24 Jun 2026
Glad to see that the genset is up and running again Bryan.
have fun with the rock crusher
Pete
Bryan1
Posted: 07:12am 25 Jun 2026
Well Pete did a bit of heating and bashing on the Jaw Crusher today now I got my LPG/Oxy all setup so the movable jaw is nice and tight again as prior use did loosen it up making the action a tad erratic.
Anyway yesterday decided to bring the lawn mower out and went to cut the grass as it was getting pretty high only to find it was running pretty rough. Cleaned out the air filter and got it running nicely so got the front yard all mowed and went out to the back only to find after trimming a few salvation jane weeds the cutter disk on the mower parted ways.
Went into the mower place and they sold me the wrong disk so went back in this morning with my old one and they reckon it should be in tomorrow
So just like my genset bringing out the old gear did need some tender loving care so the next one's are my old whipper snippers as I do the new plastic bulbs for priming the 2 stroke engine and the way I tune them they do cut sick on weeds
Regards Bryan
