Local Time 08:33 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Bridge rectifiers
dave r
Posted: 07:51am 23 May 2006
Good day
Just a question from someone not really up with electronics. I have just purchased 3 15 amp recfifiers from Dick Smiths. I noticed that the circuit on this site uses 3* units where as the circuit on yourgreendream site uses 2. Can someone just explain the difference
Thanks in advance
Dave R
dave rankin
Posted: 08:59am 23 May 2006
Hi Dave
Each Bridge Rectifier has 4 diodes in it, but we only need 2 for each phase ( wire ) from our alternator. So on a 3 phase machine ( 3 wires ), we need 6 diodes, or 1 and a half bridges. So thats explains why some sites only use 2 bridge rectifiers, using all 4 diodes in one and 2 diodes in the other.
But what I prefer to do is use all 4 diodes in each bridge rectifer for each phase. If a bridge rectifier is rated at 15 amps, then by doubling up on the diodes I've doubled the amps it can handle, up to 30 amps. So by using 3 bridges, I've doubled the power it can handle compared to using only 2 bridges.
So I get twice the capacity for only 33% more cost.
But either way is fine.
dave r
Posted: 11:54pm 23 May 2006
Thanks for the reply Glenn
That makes it easy to understand.
Dave
dave rankin
wallablack
Posted: 10:54pm 28 Apr 2012
This is, I am assuming, the wiring diagram in question.
LINKY
Does using 2 instead of 3 bridge recs have any performance downfalls?
Foolproof systems do not take into account the ingenuity of fools.
Posted: 11:20pm 28 Apr 2012
Since the circuit with 3 bridge rectifiers ( as shown here ) uses 2 diodes in parallel, there may be a tiny gain in power as there is less loss through the rectifier, but I guess the gain would be almost unmeasurable. So no, I dont exepect there is any noticable performance gain in using 3 bridges instead of 2.
There is a reliability gain with 3 bridges, since each diode is passing less current.
wallablack
Posted: 11:57pm 01 May 2012
Okay, so, current question.
If I had 2 x 50 Amp 1000V KBPC5010,s wired -ive to -ive / +ive to +ive what would the voltage and amperage rating be?
If I had 3 x 50 Amp 1000V KBPC5010,s wired -ive to -ive to -ive / +ive to +ive to +ive what would the voltage and amperage rating be?
Edited by wallablack 2012-05-03
Posted: 02:10am 02 May 2012
A. 1000V 50amps
B. 1000V 100 Amps
Basically your doubling its current carrying capacity, for and extra 50% in cost. Thats why I prefer the 3 bridge recitfiers.
