Local Time 19:05 24 Oct 2026 Privacy Policy
Forum Index : Electronics : Fisher & Pykel  Motor Driver.
Marcwolf
Posted: 09:44am 13 Sep 2025
Hi
We have an old washing machine that the electronics are totally fried. However the motor still seems to be good as we can drive it using PWM and one of the winding.
What we want to do is possible to drive it fully, one direction only, so we can use the washing machine drum for dehusking i.e. some plants have their seeds (peas) in a pop.
Does anyone have a circuit that I can user, or is there a module online I can buy.
Many thanks
Dave a.k.a. Marcwolf
johansen
Posted: 04:52pm 14 Sep 2025
If this is a 7 phase motor i would consider reconnecting it from Y to a 7 phase polygon connection.
You then drive it with a 3 phase vfd
since you probably have 21 or 28 coils, you can draw the polygon out and select three connection points as close to 120 degrees apart as possible.
johansen
Posted: 05:18pm 14 Sep 2025
It would probably be easier to build your own 7 phase motor controller with an arduino and chat gpt, than it would be to do it this way:
https://www.researchgate.net/figure/a-Connection-diagram-of-three-phase-to-seven-phase-transformer-b-Seven-Phase-unbalanced_fig1_339805348
johansen
Posted: 06:34pm 16 Sep 2025
https://www.thebackshed.com/windmill/FPRewire.php
Turns out they are 3 phase so, just run it from a vfd.
The 7 phase i read about on another forum comes from swapping the rotors.
