Local Time 19:44 24 Oct 2026 Privacy Policy
Forum Index : Electronics : Identification
lew247
Posted: 04:26pm 16 Sep 2024
Does anyone know the name of this micro tactile switch or where I can buy or aquire one other than buying new Type-C lcd display board with for around GB £50?
I'm happy to desolder one if anyone even knows where to get any 2nd hand or broken board with this type switch but ideally I'd like to buy a similar one new
the dimensions of the white plastic bit are appx 4.5mm X 1.9mm
Revlac
Posted: 09:31pm 16 Sep 2024
At first glance I thought there was heaps of them, then find nothing with those dimensions.
There might be something close to that size, the side buttons on Mobile phones? haven't taken one apart to be sure.
Cheers Aaron
Off The Grid
Marcel27
Posted: 01:57pm 17 Sep 2024
I found this one on the side of an pcb from a Samsung/Horizon remote.
3.15 mm x 6.2 mm with solder contacts, the switch body is 4.25 mm.
Edited 2024-09-18 00:19 by Marcel27
lew247
Posted: 07:37pm 17 Sep 2024
  Marcel27 said  I found this one on the side of an pcb from a Samsung/Horizon remote.
Brilliant
Do you happen to have a pcb reference number so I can try and locate one to "pinch" that switch from?
Marcel27
Posted: 09:33pm 17 Sep 2024
I think it is easier that I send the part with the switch by normal mail. Cost me only €1.80 to the UK. Se me a PM with your address.
Marcel27
Posted: 04:35am 18 Sep 2024
Marcel27
Posted: 08:25am 06 Oct 2024
Lew,
Could you salvage the switch from the board I sent to you?
Marcel
