Local Time 01:38 25 Oct 2026 Privacy Policy
Forum Index : Electronics : 24 volts relay off 12 volts
Arthur
Posted: 10:59am 13 Mar 2009
Hi, I want to operat a 24 volt relay off 12 volts, I remember in the distant past I used to do this unforrtunatly all my notes and circuits as well as the house were distroyed by fire. I would prefer that it's done without using another relay. thanks Arthur
9c12m
Posted: 11:47am 13 Mar 2009
There is a cct that might be of some interest at:
http://www.geocities.com/SiliconValley/pines/5440/relay.html
Arthur
Posted: 12:22pm 13 Mar 2009
Thank you very much for the info that chap has some awsome stuff ion his web site Arthur
catchnthe-))))
Posted: 10:05pm 21 Mar 2009
I have a similar condition. I have 12 volt relay, coil
that energizes and 50 amp set of contacts. I would like to control a 24 volt circuit using this 12 volt unit.
any help appreciated.
Chuck
Freedom allows us a lot "Please don't abuse."
CraziestOzzy
Posted: 12:02am 22 Mar 2009
You will need to protect for in rush current, use a cap to prevent carbon burn on your relay allowing for longer life.
I would recommend using 12volt DC relays taken out of a car/truck, as they are usually high current 12/24 volt combos. Wiring details are usually straightforward and marked on the case.
catchnthe-))))
Posted: 04:34am 22 Mar 2009
CraziestOzzy,
Thanks,for the info.the relays I have now are Automotive
Bosh HD. will a condenser from the old style car points system work.I am asuming attaching it to inlet side of contact.
Thanks,
Chuck
CraziestOzzy
Posted: 10:20am 22 Mar 2009
  catchnthe-)))) said  ...will a condenser from the old style car points system work.I am assuming attaching it to inlet side of contact. Thanks,
Chuck
Yeah it would work, with reservations...as long as it is rated for the current experienced. I would prefer going over the rated current only to prolong life of your relay.
Have the condenser as close as possible to relay and as far as where to attach your condenser, the polarity should be marked on the condenser if it electrolytic or not.
I would recommend personally the use of the standard electrolytic capacitor you typically see on electronic PCB boards (correct sub-family of course) with the typical few components of added circuitry for relay protection in the case of your application.
Google has buckets of info and examples if you go this way.
Cheers.
catchnthe-))))
Posted: 02:49pm 05 Apr 2009
Removed and started New thread.
thanks,ChuckEdited by catchnthe-)))) 2009-04-07
