Local Time 02:04 25 Oct 2026 Privacy Policy
Forum Index : Electronics : MU45 panel meter customization...
Posted: 08:44am 14 Mar 2023
Hi everyone.
I need to customize an MU45 standard analog moving-needle type meter to show between 0 and 3v.
There are various versions of the MU45 available at Jaycar etc, but I no longer have the data for the multiplier or shunt values to customize these meters.
Can anyone suggest a meter type and suitable multiplier for 0-3v use?
Thanks.
WHY do I need an analog meter in this day of digital?
I need to build a RSSI meter, and analog meters are still the best for this - IMHO.
I have a RSSI output of 0v to 3v to play with, so I need to arrange for a MU45 meter of any type, to show 3v at full deflection/range.
pd--
Posted: 09:58am 14 Mar 2023
https://littlebirdelectronics.com.au/products/large-3v-analog-panel-meter
its a adafruit unit so probably available at a few different  suppliers
Posted: 11:55am 14 Mar 2023
The Jaycar site indicates the MU45 coil is 1mA FSD so for 3V you want a total resistance of 3k. The coil resistance isn't specified so measure it and replace the existing series resistor with one that gets a total of 3k. Or just use a 5k multiturn trimmer and calibrate it.
Posted: 11:21pm 14 Mar 2023
Both excellent suggestions - thanks, chums.
I used those analog meters in my teenage years, but that was quite some time ago, so I have forgotten the details about working out the multiplier or shunts.
Chopperp
Posted: 01:24am 15 Mar 2023
Hi Grogs
You may be interested in this for drawing meter scales. Sorry it's a Windows prog.
Bit fiddly but works quite well. I do have the paid version.
Brian
ChopperP
Posted: 02:35am 15 Mar 2023
Sounds excellent.
If I get the prototype going OK on the bench, perhaps I could get you to whip me up a scale seeing as you have the paid version?
Only needs three colour zones left to right: RED, YELLOW, GREEN for weak, OK and good signal levels.
Posted: 07:19am 15 Mar 2023
Any of the 'Mites drawing commands could do a simple scale like that.
You don't even need one with a screen with Peters latest phantom LCDPANEL and SAVE COMPRESSED IMAGE.
Chopperp
Posted: 08:47am 15 Mar 2023
@ Grogs
Found a MU-45. Will have a quick go. I had to open the program up for another task anyway.
@ phil99
You are probably right
Brian
ChopperP
Chopperp
Posted: 12:15pm 15 Mar 2023
Hi Grogs
I take it back. The program is very fiddly & works sort of sometimes.
See what you think of the attached. Some cutting out is required & may need upscaling a tad. Was OK on 210mm A4 on the screen, but the test PDF printed out slightly smaller.
Brian
Grogs test MU45_09.pdf
ChopperP
Posted: 10:20pm 15 Mar 2023
"PDF printed out slightly smaller."
It probably added margins and re-scaled the image to fit. Some programs have an "actual size" option to prevent that. If not save as PNG.
Posted: 03:20am 16 Mar 2023
Thanks, Brian - I should be able to work with that!
Chopperp
Posted: 07:56am 16 Mar 2023
@ Grogs. Great news. Let me know if updates are required.
@ phil99. Points noted. Thanks.
The program has the facilities for printer calibration. I used 2 printers for  doing this project; a Brother mono laser & Microsoft print to PDF. I did the cal for each which were slightly different. I didn't try my colour inkjet as it is a bit low on ink.
To print correctly, the calibration needs to be done with the printer doing the actual printout.
As this was intended to be a demo for Grogs, I just wanted something in the ball-park. His printer may be slightly different to mine anyway & give a slightly different print size out.
I did wonder if the margins did come into play but I wasn't particularly worried. No problems in doing a other one if Grogs says there is room for improvement.
Brian
ChopperP
