Forum Index : Electronics : Aerosharp 2.5 Kw Cheltenham VIC HR-INV-X01-020 * 6
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1158 |
These six Aerosharp Inverters are now available for $55 . I have been watching at $145 but are pickup only. I am in Sydney. I would take three or more. Anyone in VIC willing to see if we can get them. I would need to get them sent once you have them. Truckit will pick them up, you would just need to put the shipping labels on them. Aerosharp 2.5 Kw Hopefully someone is interested. F4 H7FotSF4xGT |
| pd-- Senior Member Joined: 11/12/2020 Location: AustraliaPosts: 122 |
I will give them a call. I will take two of them if you wont the other four |
OK, sounds good. Thanks Gerry F4 H7FotSF4xGT |
Heading down there now to pick them up |
Six brand new Aerosharps ill PM my details |
Very nice. Thanks for getting these. Hopefully I can get my share to Sydney without breaking the bank. Gerry F4 H7FotSF4xGT |
| poida Guru Joined: 02/02/2017 Location: AustraliaPosts: 1498 |
pd, you know you were wondering how to get the current sensors? Each board in those Aerosharps has 3 good sensors. Sometimes genuine LEM, sometimes alternatives with same pinouts. The pinouts also will match with the mppt board if they are 3 pin type. (please check this before you solder them in place, I could be wrong, and on about 1,000 times in the past I was wrong) 4 pin type LEM sensors will need a bit of fiddling with. But 3 x $25 LEM sensors per board is worth the time to desolder. wronger than a phone book full of wrong phone numbers |
Definitely, thanks for that They are the 4 pin type lem casr 15 np i have the data sheets so wont be hard to figure out and 13 $20 capacitors. its amazing how things just popup when you need them. just need to figure out the choke |
