Local Time 21:09 24 Oct 2026 Privacy Policy
Forum Index : Electronics : USA source for split phase toroidal trans
rustyrotors
Posted: 12:43am 06 Feb 2023
after searching high and low for affordable toroidal trans in the USA, i found potential source on ebay.. search for "voltage converter." you will find a few different variations of basically an autotransformer box for under $100, some are supposedly rated for 5000w and have a toroidal trans inside with two 115V windings in series. i ended up purchasing this one:
https://www.ebay.com/itm/124889104671
its not potted, all you have to do is add your secondary winding. this trans is roughly 180mm width x 100mm height. the windings measure 0.6 ohms in series, so the 5kw rating seems to be fairly accurate
Edited 2023-02-06 10:47 by rustyrotors
tinyt
Posted: 04:05am 06 Feb 2023
Good find!
I think it is an autotransformer, so for an isolation transformer application like in an inverter it will probably have to be rated at 2500 watts.
You will probably need to add more turns to the 110/220v windings to lower flux density and no load power draw.
If you add the mosfet drive winding, using multiple strands of small dia. magnet wires, one strand at a time will allow you to make the most use of available toroid hole space.
Edit: uploaded picture will not show, deleted
Edited 2023-02-06 14:22 by tinyt
Posted: 05:33am 06 Feb 2023
  Quote  I think it is an autotransformer, so for an isolation transformer application like in an inverter it will probably have to be rated at 2500 watts.
Exactly. For a 2:1 autotransformer only half the output VA is provided by the core, the rest comes from the input.
wiseguy
Posted: 05:46am 06 Feb 2023
TinyT is right the auto-transformer only needs to be capable of 2.5kW.
For 5kW of 230 the current required is 21.7A but at 115V it is 43.4A.
The input current has two 21.7A components one for the transformer primary and the other is added to the 21.7A 115V secondary so it adds to the input voltage to equal 230V (@21.7A).
The input supplies the whole 5KW the transformer transforms 115V @ 2.5kW.
I decided to sketch it to aid with the understanding, sorry but the graphics let me down the currents do not show the dash of the A and look more like an upside down V. The transformer is drawn like a conventional tranny but the result is the same as a centre tapped auto style winding.
Edited 2023-02-06 15:47 by wiseguy
Cheers Mike
rustyrotors
Posted: 12:41pm 06 Feb 2023
ok i will keep it under 2.5kw on 115v. that makes sense for reasonable heat dissipation too, probably get a bit toasty at 5kw
my local grid runs a little hot at 125V, no load pulls about 10W. I will probably run it as is, im using it to build a backup inverter
rustyrotors
Posted: 10:34pm 06 Feb 2023
it ended up taking 18 primary turns to make 115/230V from 15V, with cross section of 40cm2, that make just under 0.8 tesla if my maths correct
Edited 2023-02-08 09:18 by rustyrotors
get real
Posted: 05:48pm 05 May 2023
you added 18 turns on top of coil? and put 15v in and got 115/230? is this right? thanks.
