Local Time 01:24 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Run Time Error 17
valterra
Posted: 04:59pm 26 Dec 2008
When using the Piclog software on an old windows 95 machine, I keep getting a run time error: File / Path access error.
Any ideas?
I can supply more info if necessary.
SparWeb
Posted: 05:02am 08 Jan 2009
Came across this question only now.
Have you solved it yet?
Piclog is trying to write a data file every 10 seconds or so. It writes a text file, an Excel file, and a html file each time. The files are in the piclog's file tree somewhere, but there are "special characters" in the path: "C:\PicLog_Ver_1-2", and the folder names are longer than 8 characters each, too.
Windows 95 was basically DOS v.6 with a clunky interface slapped upon it, a giant leap forward after Windows 3.11, which was DOS v5.5 with an even clunkier interface slapped on top. Somewhere along this process of seemingly random evolution, new characters were permitted in file and foler names, and they were allowed to be longer than 8 characters each. That might be your problem.
If you haven't fixed your problem yet (I first suggest installing XP, also known as DOS v7 with a somewhat streamlined interface) then let me know.
Steven T. Fahey
Posted: 01:01pm 08 Jan 2009
I did look though my junk pile for a Win95 bootable HD, no luck. The earliest version I have is Win98, and the PicLog works fine with that.
Cant offer any idea's at all I'm afraid.
Gill
Posted: 12:53am 09 Jan 2009
I understand old computers do not have the processing speed, bus speeds, the ram or the storage capacity to suit the later operating systems yet can still more than adequately perform data collecting functions to name just a few. The older operating systems were tailored to that hardware.
I would check which version of Windows 95 you are running. It will have to be Version C. I can't recall now but it could be that versions 95, 95A, & 95B are 16 bit whereas version C is 32bit? The software will be 32bit.
I ran windows 98 Second Edition for many years and it could be streamlined to reduce HDD usage and suited older computers originally running Win 95.
So you must run Win 95C or later for the software to work.
It's good to see the old pluggers still doing useful work.
Cheers Gill _Cairns, FNQ
BjBlaster
Posted: 12:49am 29 Jan 2009
All versions of win95 are 32bit, it's just that 95c had a newer kernel (as MS called it then) that supported more hardware and VB calls like script writing etc. I tried it on my ol' 486 DX running Win95c with SP1 for 95 and scripting update 5.5 and it runs fine. You will also need the VB6 runtime package if you haven't installed that already.
Bj
Check out my projects here in:
Bj's Shed
