Forum Index : Electronics : so what's the furthest you've done a radio link with fleabay modules?
Quite an interesting read. https://www.theregister.com/2021/11/24/lora_to_the_moon/ and, largely unrelated but a face-palm, this was linked from that article... https://www.theregister.com/2021/02/19/airspeeder_alauda_drone_investigation_with_photos/ the pictures of the quality of work are shocking. . Edited 2021-11-29 18:14 by CaptainBoing |
| Pete Locke Senior Member Joined: 26/06/2013 Location: New ZealandPosts: 186 |
A great read thank's. |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10073 |
Pictures are truly staggering - erk.... Those prototyping boards should only ever be used to prove a concept on the bench IMHO. Most of the prototype things I build, I still design an "A" variant PCB for them, then fix anything I find wrong in the "B" variant. Point is, I get a professional PCB made even when I am prototyping anything. I don't think I would be comfortable designing wireless links for a drone though, cos as this case has shown, one bad bit of design COULD potentially put commercial aircraft at risk - that could have ended REALLY BADLY if it strayed into the path of an aircraft....yikes.... ![]() In addition to the kill-switch, I would have liked to have seen at least some kind of altimeter kill-switch thing, so if you lost all wireless control, and it happened to climb higher then a certain height, the altimeter thing would kill the power, and the drone would fall out of the sky - but not be able to climb up into the habitat of the commercial aircraft. But then, I would not be doing drone controls anyway! ![]() Smoke makes things work. When the smoke gets out, it stops! |
