Forum Index : Electronics : Calculate how many conductors can fit through a hole
Haxby
Posted: 11:39pm 29 Jun 2021
Was there an online calculator somewhere that shows how many conductors can fit through a hole?
I want 70 conductors through a 54mm diameter hole and need to know how thin they should be...
Posted: 11:57pm 29 Jun 2021
With a rough back-of-the-envelope calculation I get a touch over 5mm OD for the wires.
Warpspeed
Posted: 03:24am 30 Jun 2021
The magic answer is.....
Seventy 5.6mm wires fit through a 54mm hole.
https://www.engineeringtoolbox.com/smaller-circles-in-larger-circle-d_1849.html
Edited 2021-06-30 13:27 by Warpspeed
Cheers,  Tony.
Haxby
Posted: 10:06am 01 Jul 2021
Thanks guys.
bob.steel
Posted: 08:45am 07 Jul 2021
Course if the hole stretches ,well!
Godoh
Posted: 10:59pm 08 Jul 2021
Hi Haxby, it may seem counter intuitive but as a former electric motor rewinder., I would often try a few different guages of wire, in a motor if the slots looked full on the winding I was going to replace.
Often I would find that instead of a large number of small wires in parallel, that a smaller number of larger wires would actually leave more room in the slot and make the wind easier.
What happens is that as you put the windings into the slot they don't stay neat and parallel, it is difficult to keep them all straight so they bunch up.
In a transformer winding by hand, such as a torroid, it may not happen as much if you are very careful.
It will depend on whether you have a bit of scrap cable of the size you want to use to test it out.
I used to cut enough short bits of magnet wire and put them in the slot just to test it out. It was amazing how many times a tight winding became easy by changing the guages.
The way to get the calculations right is to work out the cross sectional area of the wires in parallel and find other combinations of conductors that add up the same.
Pete
Warpspeed
Posted: 12:21am 09 Jul 2021
  Quote  What happens is that as you put the windings into the slot they don't stay neat and parallel, it is difficult to keep them all straight so they bunch up.
I can see that laying a winding carefully into a rectangular slot with relatively tight U turns between slots might be rather a challenge to get the conductors laying flat in neat layers without tending to pile up around the sharp corners. And thicker wire should I would think be easier to deal with, especially if it happens to be a convenient size with relation to slot dimensions.
As soon as you start getting crossovers around the corners you are getting into deeper and deeper trouble.
Toroids are rather different in that its much easier to lay the conductors parallel right where they pass through the hole. Heaps of room between turns going around the outer circumference as it all spreads out.
Some things will be obvious to the old toroid winding veterans, but the novice may not have thought of.
The fine wire with the highest turns always goes on first. It could be either the primary or the secondary, but always the higher voltage winding goes on first.
The reason being the smaller wire produces a much smoother winding. Very heavy gauge wire will produce a lumpy winding, which on the outer final layer does not matter.
Much more difficult to wind fine wire over a very lumpy previous layer.
The other fascinating thing about toroids is how many turns will fit onto each layer.
If you start with one single central wire, six more wires will cluster very neatly around that, a perfect fit.  I think everyone knows that.
What may be a surprise is the next layer will fit exactly six more wires than the layer underneath. And the next layer again six more wires than the layer underneath that.
So centre wire = 1 wire.
First layer 1+6 wires = 7 wires total
Second layer 1+6+6 = 13 wires total
Third layer 1+6+6+6 = 19 wires total   and on and on it goes forever.
But the really interesting thing for us, is it works the other way too.
When winding a hypothetical toroid, (without any insulation between layers) theoretically, if you find after measuring your hole, and from the wire diameter, lets say 280 turns will just fit around the inner circumference in the first layer.
You can assume that the next layer to go in will be six turns less or 274 turns.
Third layer again six turns less 268 turns and so on.
Actually its never quite that good, extra insulation and small gaps between the wires reduce what will fit, but its a pretty good initial guide to estimating what might be possible when trying to figure out if a design is even possible.
So if 280 turns will fit on the very first layer, in a perfect world, on the sixth layer 36 less turns (244) might fit. It won't in practice.
But if you only need say 235 turns per layer it might be a pretty safe bet that six layers of 235 turns should fit onto that core.
Edited 2021-07-09 10:29 by Warpspeed
Cheers,  Tony.
Posted: 01:35am 09 Jul 2021
Unwound a piece of heavy power cable. The rule of 6 more per layer works but not quite in the way shown.
Second layer 1+6+(6+6) = 19 wires total
Third layer 1+6+(6+6)+(6+6+6) = 37 wires total
Warpspeed
Posted: 01:51am 09 Jul 2021
Yes you are quite right Phil.
The important thing to remember is that each successive layer is 6 more.
Cheers,  Tony.
