Local Time 06:53 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Soft start 3kva transformer
Haxby
Posted: 11:10pm 28 Mar 2021
Hi all,
I have a 3 kVA isolation transformer that trips the circuit breaker on switch on. What's the usual way to stop that happening? NTC thermistor? Or resistor "precharge"?
Revlac
Posted: 12:07am 29 Mar 2021
What style of transformer is it?
Been using a 2kva in the house no problems starting, its Double C Core I think.
Its runs from a HF Inverter, just plug in and it works.
Cheers Aaron
Off The Grid
Haxby
Posted: 01:08am 29 Mar 2021
It's a toroidal transformer. It trips a C curve RCBO about once every 3 times I plug it in. I got it off eBay so I'm not sure of its history.
Warpspeed
Posted: 01:57am 29 Mar 2021
Pretty typical for commercial toroidal transformers that run at a fairly high flux density.
All you can do is soft start it through a series resistor for a second or two.
How about a three position switch ?  off/soft start/on
Cheers,  Tony.
rogerdw
Posted: 02:27am 29 Mar 2021
I occasionally work on gear that has a pretty gutsy NTC thermistor in series with the mains input.
One I replaced was on a decent sized switch mode power supply (27V 22A) and the replacement I found was from element14  ...  part number 2113008
It's 2.5 ohm and good for 15 amps.
Resistance @ 100% Max Current: 0.03 ohms
Resistance @ 50% Max Current: 0.07 ohms
Datasheet here  ... http://www.farnell.com/datasheets/1598322.pdf
I've often wondered if they would be useful for some of this work where we worry about toroid windings or capacitor charging inrush blowing fuses and circuit breakers all the time.
This link shows their offering up to 50 amps max steady state current  ...
https://au.element14.com/c/circuit-protection/thermistors/inrush-current-limiting-icl-ntc-thermistors
Cheers,  Roger
Haxby
Posted: 07:41am 29 Mar 2021
Ok NTC thermistor sounds like the easiest solution.
Thanks all!
InPhase
Posted: 06:22pm 29 Mar 2021
Light bulb in series with the line and a switch to bypass it?
Warpspeed
Posted: 10:20pm 29 Mar 2021
Thermistors work fine for a fixed occasionally switched heavy load, but may have issues with a general purpose workshop type isolation transformer used for testing purposes.
See how it goes, but a thermistor need time to cool before the protection fully resets.
Rapid cycling of the on/off switch with a hot thermistor will not provide the expected surge protection.
Still, a very big step in the right direction.
Cheers,  Tony.
Solar Mike
Posted: 11:49pm 29 Mar 2021
Jaycar sell a kit for "Soft Start" anti surge applications, see Kitset , based on an article from silicon chip mag, july 2012.
I have built two and they work well, when powering things like drop saw's with inverter AC supply; no reason it wont work with a transformer, noted that the kit rating is 10 amps.
Mike
Edited 2021-03-30 09:50 by Solar Mike
poida
Posted: 08:21am 30 Mar 2021
  InPhase said  Light bulb in series with the line and a switch to bypass it?
why not?
cheap.
easy to do.
Pete Locke
Posted: 08:17am 31 Mar 2021
The humble incandescent lamp has served me well in the industry as a fuse when repairing things. It will show you when something isn't right, and not blow anything else up in the process. Apart from real estate it may take, it's a brilliant....oh crap, unintended pun....anti surge/fuse option.
Pete'.
