Local Time 21:09 24 Oct 2026 Privacy Policy
Forum Index : Electronics : power meters
GWatPE
Posted: 12:43am 26 Oct 2008
Many readers will be familiar with the portable plug-in power meters that are available.
I have a sparOmeter that I have had for many years. I have a pic-based kit unit from Dick-Smith[no longer stocked], and several from Jaycar.
The sparometer and the pic kit are single direction measurement only, and are suitable for measuring consumption by a normal AC load.
The Jaycar plug in units are bi-directional. These can also be used in line to measure power back to the grid from a grid connect unit. No rewiring needed. They display down to 1W, with 1W resolution up to 2500W. They are lithium battery powered and retain data when disconnected.
I would consider this type of meter a must for RE grid connected systems. The rapid update rate of the display gives more power info than metering on the inverters.
Gordon.
become more energy aware
oztules
Posted: 07:25pm 26 Oct 2008
Rats.... just one more thing on my must have list......
.........oztules
GWatPE
Posted: 09:47pm 26 Oct 2008
Hi oztules,
I can probably send you one with some leading edge tape.
Gordon.
Bolty
Posted: 01:19pm 07 Nov 2008
Gordon make sure that you keep the leading edge tape flat when you send it!You know what happened to my turbine when I did not fit the tape properly!
Bolty
