Local Time 06:54 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Wifi Alarm Module
Dinosaur
Posted: 06:33am 25 Feb 2021
Hi All
Trying to find a Wifi module that will do the following.
1:    Connected only to Power (when there is an Alarm)
2:    No cpu or pc attached.
3:    2.4 Ghz only.
The idea is that the module has it's own MAC address and can be setup to join
a network.(With a laptop)
The Network router will then issue an IP based on it's MAC address.
I don't need to communicate with any intelligent device, I just need to be aware
that it has powered up. (When the IP becomes "Live")
Saw some detail on a Micromite user in the usa using a wifi module (ESP8266),
but can't seem to find any examples of it being used as per my needs.
Your average Wifi door alarm could be adapted but range and making it weather proof
could be an issue.
The network currently has 24 TP-Link HS-100 smart switches and I have allowed for
another 8 Alarms. Theoretically I could use a relay and power another smart switch
for each Alarm, but that means converting low voltage dc to 240 vac with relays/contacts. I would rather just power a module.
Has anyone any experience in this area ?
Hervey Bay Qld.
disco4now
Posted: 10:52am 25 Feb 2021
Have a look at
Annex
It runs on the ESP8266 and could be made to do pretty much anything once it powers up.
It would connect to the wifi network and get an IP address, can even then send an email if desired.
F4 H7FotSF4xGT
Dinosaur
Posted: 10:02pm 25 Feb 2021
Hi All
Many thanks for that.
It looks like quite a capable package.
Good to see it is my favorite language (Basic)
I have no problem donating to that kind of developer, as he/she has obviously done
a great job.
Have organised a board from Jaycar to play with.
Once again, Thank you for your time.
Hervey Bay Qld.
Dinosaur
Posted: 09:28am 27 Feb 2021
Hi All
Just for completeness this was the easy solution.
Jaycar ESP8266 XC3802 $25
https://www.jaycar.com.au/wifi-mini-esp8266-main-board/p/XC3802
Micro usb port that became visible as ttyusb0 in Linux.
Of course the information is all geared to ArDuino and additionally is wrong as well.
Preset baud rate is 115200 N,8,1 and not 9600.
Set it up with a Linux Terminal program and sent AT commands followed by Cr/Lf.
It fires up with an IP as 192.168.4.1 on it's own name SSID.
Then by using these commands:
AT+WPS=1  enable station mode
AT+CIPSTA="192.168.0.25","192.168.0.1","255.255.255.0"     sets IP,gateway,Netmask address.
AT+CWJAP_DEF="My SSID Name","password"    sets new name & password.
That's it. Now every time power is applied, it is visible on my Network.
The router will also be set to the MAC address, so whenever I get a successful ping
from that device it is translated as an alarm in that particular zone.
Will test it on Sunday on site to see what distance I can get considering trees etc.
Didn't need Annex after all.
Hope this helps someone else in future.
Edited 2021-02-27 19:29 by Dinosaur
Hervey Bay Qld.
Posted: 12:40am 03 Mar 2021
  Dinosaur said  Jaycar ESP8266 XC3802 $25
Timeliness of delivery may have made all the difference to you, but $25 is quite a markup for an ESP8266 D1 Mini: $4.42AUD here
Dinosaur
Posted: 02:24am 03 Mar 2021
Hi All
The board from Jaycar has the ESP8266 sub board mounted on a USB to TTL (CH340G)
main board.
Although that is not the board I will use in the field. Now I know it does what I want it to,I have bought 2 others which have an ipex Antenna plug on it ($16) which
allegedly gives 6dB improvement.
So all up with antenna $23.
Hervey Bay Qld.
Posted: 03:06pm 03 Mar 2021
  Dinosaur said  The board from Jaycar has the ESP8266 sub board mounted on a USB to TTL (CH340G) main board
Right. It's labeled "D1 Mini", same as I linked to, except that it has the female headers already soldered on.
ESP8266 D1 Mini with antenna for $4.86AUD here
