Local Time 06:54 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Using 12V Smart Charger on a Battery With Equipment Connected
Chopperp
Posted: 08:00am 01 Feb 2021
Hi all.
Just wondering what the thoughts are on using a "Smart" 12V charger on a battery with equipment e.g. a 2-way radio, connected.
I have a couple of so called Smart chargers & the outputs can go over 15V at times. As well they seem to rely on a low-ish charge current to switch back down to the trickle or maintenance charge & voltage.
My thoughts are that if a load is attached to the battery, the charge current may not drop low enough for the charger to detect when the battery is fully charged. (I think some chargers will time out if full charge is not reached in a given time frame).
You will also have the varying load such as a radio on transmitting, upsetting the charging routine.
In my thinking, a fixed voltage charger (or power supply) my be the better way to go in this scenario.
Thanks,
Brian
ChopperP
Warpspeed
Posted: 08:42am 01 Feb 2021
You are probably right Brian.
It does not take much to outsmart a "smart" charger.
They seem to be more suited to just straight charging a battery that has been removed for charging.
A typical automotive system has an alternator regulated pretty much to about 14.2v or something close to that all the time, and the system loads are  all over the place, with some very large and sudden changes.
Constant voltage charging does seem to work quite well in that application, and its simple.
Cheers,  Tony.
Chopperp
Posted: 09:13am 01 Feb 2021
Thanks Tony
I know some modern vehicle alternators (D-Max) drop their voltage after a bit to save some power. Frustrating when trying to charge an external caravan battery without using a DC-DC converter.
Brian
ChopperP
Warpspeed
Posted: 09:27am 01 Feb 2021
One solution to the caravan problem, is to fit a second alternator that works completely separate from the cars existing electrical system.
Far fewer problems and surprises !
Cheers,  Tony.
Murphy's friend
Posted: 09:00am 02 Feb 2021
  Chopperp said  Thanks Tony
Brian
Brian, I happen to drive a D-Max with that smart alternator. There are two ways to outsmart it.
1. drive with the headlights on.
2. remove the 'smart' sensing bit (just cutting a  wire) and replace it with a small switch so you can choose 'smart' or 'dumb'.
I have the second option.
Chopperp
Posted: 09:52pm 02 Feb 2021
Hi Guys,
Re D-Max.
A friend of mine traveling from Toowoomba around Australia in his new D-Max was wondering why his van or auxiliary battery (or both) wasn't charging.
I think he tried various things & it wasn't until he got to Kununarra, WA that an auto electrician told him why & promptly sold him & installed a DC-DC converter at a much inflated price.
No suggestion of turning on the headlights, which he would have known about.
Brian
ChopperP
