Local Time 07:04 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Down the rabbit hole..
oreo
Posted: 04:41am 16 Dec 2020
Greetings from Canada.
Didn't see a good place for introductions, so I figured I would post something here.
I'm  a car guy and I have always chuckled when someone would post on a forum saying "I just got this turbocharger really cheap and need help installing it".  They didn't realize that the turbo was a very small portion of total cost of an install, and it was very unlikely that they would move ahead, once they found out the total cost.  Car Build
BTW, I just got some free solar panels :) -now it's me realizing that this is a small portion of what needs to be done.  I am a little stubborn though, and decided I am going to give it a go anyway.
Here are my challenges.
1.  Hydro is pretty cheap compared to other places in the world(of course we think it's overpriced).  Off peak is 10.5/kW (12hr/day) ranging to 21.5/KW(7hr/day) for On peak.  There is a mid peak in the middle.  Multiply by .7 to get USD.  As a result, there are relatively few solar installs.  Payback for a typical system is 12yrs (selling back to the utility).  So I am considering this more of a hobby right now.
2.  Due to WAF (wife acceptance factor), I am having to install the panels in the most ludicrous manner, in a spot which is far less than ideal.  Total qty of panels is also very small. Hopefully over time I can install more panels in better locations.
3.  I'm stubborn and like to do things my own way, even when I should know better.  (I am learning to start over earlier, when I am not getting the results I want).
On the positive side, I am working for an audio company, and the recycling bin is a good place for me to get parts I can use in this build.
Typically when you do a search for DIY solar, you get someone talking about buying all the components and installing them without using a contractor.  It was refreshing finding this forum where so much more than this is being done.  I have learned quite a bit over the last couple of weeks just reading threads, which will certainly help me a lot. Thank You! Hopefully I can contribute as well.
Greg
Greg
