Local Time 06:31 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Allans Mad-Inverter Project
     Page 1 of 5
shallowal
Posted: 07:30am 09 Feb 2020
Thought I would join the party (somewhat late I think) and get my inverter project underway.
So far I have the transformer wound and the boards built, and am somewhat through testing the board functions and am stuck on a couple of problems that I would like some help with.
I have set up a test rig with a 12V supply to the Arduino, a (nominal!) 48V supply to the power board, and an AC supply to the Voltage feedback circuitry through a Variac. I have no FETs or caps on the power board and the transformer is not connected.
1. The only way I could get the EG8010 chip to provide a continuous output was to add a large cap to the voltage sense inputs. Without the cap I get a 1.5v ripple on pin 13 (VFB). With the cap there is no ripple and the EGS8010 doesnt complain about under-voltage. I checked that all the components including the 4.7uf and 0.1uf caps are soldered correctly and connecting to the signal path.
2. In this config I get nice 50Hz square wave signals out to the IR2110 on pins 10 and 12. I also get a nice 50Hz square wave from the IR2110 on pins 1, but Pins 5 and 7 have approx 16-17 volts fixed.
On the PWR BD I can see the totem-pole drivers on the ground side of the bridge delivering around 17v to the Gate's of the FETS as per the output of the 2110's, but on the high voltage (48V) side I have 16.5V fixed on both collectors of the Totem Pole pair.
Any suggestions, or help as to how it is supposed to work?.
I have a reasonable understanding of electronics, but I am missing a couple of key points here I think.
Allan
Warpspeed
Posted: 09:11am 09 Feb 2020
Suggest you get the EG8010 datasheet if you don't already have it:
https://www.lz2gl.com/data/power-inverter-3kw/eg8010_datasheet_en.pdf
1/ pin 13 should be +3v when the ac on the secondary is 230v (or whatever its supposed to be).  A small amount of ripple should be o/k because the EGS8010 just takes a single fast voltage sample reading, and if its +3v at the instant of measurement its happy.
It will then attempt to ramp the output up or down to achieve the +3v goal. If after three seconds the output is below +2.75v the EGS8010 shuts down. If after 0.3 seconds the voltage is above 3.15v it also shuts down.
If pin 13 is deliberately held at very close to +3v, either from your variac, or a dc supply, the EGS8010 should be able to run continuously.  But a lot of ripple on pin 13 might trip shutdown if either of the above undervoltage or overvoltage conditions are met.
2/ The IR2110 circuit is probably o/k, but the high side part of it cannot get any power until the mosfets are connected up.  There is a voltage pump circuit that uses a diode that supplies power to pin 7 to the capacitor between pins 7 and 6.
That capacitor cannot charge up until the lower mosfet turns on. As the lower mosfet is not yet there, that cannot happen.
So the low side drives should both be working, but both high side gate drivers are probably not working, but should when all the mosfets are fitted.
Cheers,  Tony.
shallowal
Posted: 10:10am 09 Feb 2020
Thanks Tony,
I had already studied the EG8010 datasheet and was monitoring the VFB line which is why I decided to smooth it with additional capacitance. I have followed a number of the other threads regarding the Ozinverter and had not noted anything about modifying the standard cct around this function, hence my question of why mine wont work without the additional capacitance. I gather from your comment that it shouldnt matter that I have the additional capacitance there.
The low side drivers seem to be working, but I couldnt understand how the high side works. The voltage pump idea sounds like the key and I've just discovered that I've installed the wrong caps here :). Thank you.
Allan
BenandAmber
Posted: 03:39pm 09 Feb 2020
Pics of your build please
Warpspeed
Posted: 09:08pm 09 Feb 2020
That voltage pump circuit is a bit tricky, and its caught a lot of people, including myself at times. If you fit the mosfets it should then run without the transformer connected, and you should then be able to see the full 48v output swing on either side of the bridge.
I have no idea what is going on with the electrolytic on the voltage feedback ???
If you tie that down with too many microfarads its going to slow down the feedback which would not be good. So its a bit of a compromise between too slow, and having the feedback go "wild".
Cheers,  Tony.
shallowal
Posted: 04:02am 10 Feb 2020
Thanks Tony,
Yep!, With the FETs installed I get the full voltage swing and can now see the high frequency output which I couldnt see before.
I reduced the Cap to 100uf, any less than that and the EG8010 wouldnt stabilise. I'll revisit it when I get everything assembled into a final setup.
Allan
Warpspeed
Posted: 04:58am 10 Feb 2020
Sounds like you are well on your way, great stuff
Cheers,  Tony.
shallowal
Posted: 06:37am 10 Feb 2020
  BenandAmber said  Pics of your build please
It's not a build as yet, but will post something when becomes something.
Allan
BenandAmber
Posted: 08:17pm 12 Feb 2020
If there is any parts I can donate or help you with please let me know
shallowal
Posted: 01:47am 14 Feb 2020
  BenandAmber said  If there is any parts I can donate or help you with please let me know
That's very kind of you to offer, thankyou.
I think I have all the parts or can get them locally without trouble.
The next major issue is sourcing a battery, to either try out the inverter or for permanent use.
I'm about to run up the inverter with my 40(+)v power supply but I doubt that I'll have enough to run a light bulb never mind anything with a 'K' in front of it.
Allan
Allan
shallowal
Posted: 01:18am 15 Feb 2020
Well, Whaddya know. It actually works!!!.
I connected a 60w light bulb OK and the configuration is just 4 FET's and no capacitors.
Woohoo!!!
Allan
Allan
Warpspeed
Posted: 01:27am 15 Feb 2020
Excellent results Allan
Before you start adding the big electrolytic capacitors and more mofets, I strongly recommend you fit a choke in series with the primary to reduce the stresses on the mosfets.  Do you still have the original iron cored Inspire chokes that came with those stainless steel boxes ?
Cheers,  Tony.
johnmc
Well Done.
Thanks for the pictures.
Cheers john
johnmc
shallowal
Posted: 01:56am 15 Feb 2020
  Warpspeed said  Excellent results Allan
I have three turns around one of the Aerosharp chokes in series with the toroid on the high frequency side already. I'll take a picture.
Allan
Edited 2020-02-15 12:01 by shallowal
Allan
shallowal
Posted: 02:02am 15 Feb 2020
Or, does that count as 4 turns?
Allan
Allan
Revlac
Posted: 02:38am 15 Feb 2020
Well Done Allan,
Can you make a note of the idle current at this stage and again after all the fets are in place, be interesting to see if there is any change.
Looks good.
Cheers Aaron
Cheers Aaron
Off The Grid
Warpspeed
Posted: 03:51am 15 Feb 2020
  shallowal said  Or, does that count as 4 turns?
Allan
Yes its four turns. You can get away with using thinner wire on the choke, because the wire length in the choke is very short. The transformer primary needs the thicker wire to reduce losses and heating.
It would be better with more turns, and if you can stack two sets of choke cores, even better still. Its a case of more is always better. A 1.5mm to 2.0mm gap spacer might be about right.
There is no substitute for testing a choke, but my gut tells me that should come pretty close.
Cheers,  Tony.
shallowal
Posted: 05:47am 15 Feb 2020
Do you mean stacked on top of each other with a 2mm gap and then the wire wrapped around the combined toroid?.
Allan
Warpspeed
Posted: 07:40am 15 Feb 2020
There are a two different ways to stack two pairs of U cores:
Both work and will have the same characteristics with the same air gap, but there is one notable difference.
The mean length of turn is different. The cores themselves are not rectangular in cross section, and if you stack two end to end the length of copper wire per turn is longer.
If you stack two cores side by side, the core cross section in the middle becomes rectangular, or almost rectangular, creating a shorter turn length.
This is all more theoretical than practical for our purposes, so in your case, do whichever way seems easiest and most natural.
If I remember correctly, the combined window area of two Aerosharp cores produces a hole 70mm x 20mm.  In theory 14 turns of 10mm outside diameter round wire should fit through that, and it is possible, but only just. Twelve turns might be a more realistic expectation.
10mm over the plastic with about 8mm diameter of copper is 4mm x 4mm x 3.142 = 50mm squared. that will run warm at 100 amps dc, but will work very well.
About a 1.5mm to 2mm spacer should put you in the 150uH and 150 amps just before saturation range.
Edited 2020-02-15 17:45 by Warpspeed
Cheers,  Tony.
shallowal
Posted: 10:40pm 16 Feb 2020
  Revlac said  Well Done Allan,
Looks good.
Cheers Aaron
I wish I had , it would have been a sensible thing to do. Unfortunately I didnt and by the time I had seen your post I had already added the capacitors and extra FETs.
Allan
Allan
     Page 1 of 5
