Local Time 18:11 24 Oct 2026 Privacy Policy
Forum Index : Electronics : amp hour ratings on sla batts
Guests
Guest
Posted: 12:01am 27 Feb 2006
hopefully a quick and easy question?  (12v 7AH SLA)
if a batt is rated at 7amp hours does that mean it should supply 7 amps for one hour? NOW the important part of the question, what would the expected voltage be after 1 hour?? asuming the batt had been fully charged (charged and then floated at 13.8v for 2 days)
peter
Posted: 11:27am 27 Feb 2006
HI
battery capacity must be specified at a particular
discharge rate, the discharge rate will affect the available
capacity of the battery. the discharge rate is usually specified in
terms of number of hours to dicharge the battery from full to flat
eg 1 hour rate (C1) your battery could have a discharge rate of
7A for 1H or 14A for 1/2H  so what you need is the hour rate for your
 battery. The voltage after 1 hour would depend on your discharge rate
 regards peterc
RossW
Posted: 07:20pm 27 Feb 2006
  Richard said  hopefully a quick and easy question?  (12v 7AH SLA)
As another poster has mentioned, it depends on the C rating.
Lets assume one of the better batteries, http://www.intercel.nl/datasheets/yuasa/NP7-12.pdf
The 7AH rating is at the C20 rate. C3 is 5.25AH, C1 is 4.2AH
  Quote  NOW the important part of the question, what would the expected voltage be after 1 hour?? asuming the batt had been fully charged (charged and then floated at 13.8v for 2 days)
They say a fully charged battery, discharged at 6A will discharge down to 9.6V (terminal voltage)
