Local Time 08:24 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Hysteresis/Time?
domwild
Posted: 10:50pm 10 Nov 2019
For some reason the subject line with its 70 char. limit did not allow me to add "Hysteresis and Time Delay Differences"?
GEYA makes two different "Monitoring Voltage Relays" GRV8-01 and GRV8-02. The 01 relay has a hysteresis AND time delay setting, while the 02 one has only a time delay setting. As I am sufficiently ignorant, I believe both are the same?
All I know is that inverters will switch off the grid at 230VAC +10% and -6% or about 256V at the high end and it is well before that switch off that I will want my hot water element to be switched in, so I save a bit of money.
The inverter switching off/in may happen in rapid succession and these settings will stop the relay rapidly firing, but why have two settings?
An aside: How tolerant is my electrician going to be when it comes to installing that Chinese relay which I purchased and which may not meet AUS/NZ standards?
Winston Churchill
