Local Time 20:56 24 Oct 2026 Privacy Policy
Forum Index : Electronics : wind and solar controller
ArcticCat
Posted: 03:42am 24 Jul 2008
Could you experts help this rookie out. I plan on building 6 solar panels roughly 70 watts each for a total around 420 wats. I also will be building a wind generator or two. I still havent decided on the style, other then it will be small, either using a ametek 30vdc motor or an alternator(wind blue system).
So, could you guys suggest a controller or two.
Ken
Gill
Posted: 04:35am 10 Aug 2008
G'day Ken,
Considering the mix of both solar and wind I'd suggest a shunt regulator or a diversion controller as suitable.
I make my own so don't know what's available on the commercial market. Perhaps you could do a search yourself now knowing what specific type to look for.
In brief, a wind regulator will suit both solar and wind whereas a solar regulator will not suit wind.
The regulator must have a capacity greater than the combined max of all the inputs. This will be expressed in Amps. So solar is 420w / 12v = 35Amps + say 2 x wind generators @ 5Amps max each, totals 45 Amps minimum for the regulator.
Hope that helps.
Cheers Gill _Cairns, FNQ
GWatPE
Posted: 09:19am 10 Aug 2008
Hi Ken,
strictly speaking, what you require is a battery maintenance device. you can use a unit like a plasmatronics PL-?? to do this. As Gill has pointed out a combination of solar and wind can use a diversion load for battery voltage regulation.
A voltage controlled switch with a fixed voltage is not desirable for ensuring a long battery life.
Gordon.
become more energy aware
