Local Time 08:35 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Transistor Replacement?
Ironmaiden
Posted: 02:51am 22 Jul 2019
Hi everyone, I have a question for those more knowledgeable?
What is a drop in replacement for the old IRF3205 Mosfet but with a higher current and voltage rating? I am looking at the IRF3306 as one possible choice. I would like to have 120 amp rating at 60 volts.
The other Mosfets in my inverter are old IRF640B that also need replacing. It would appear the Infineon BUZ 30A H is a suitable replacement one for one with the IRF640B?
Thanks in advance for any help.
Robert
Madness
Posted: 03:16am 22 Jul 2019
An HY4008 TO220 will drop straight in with much better specs.
If you look here you can enter the required specification and get a suitable replacement.
You should look at replacing all the capacitors as well.Edited by Madness 2019-07-23
Ironmaiden
Posted: 06:04pm 23 Jul 2019
Madness, Thanks for the link. Not much comes up other than IRF3205 variants.
I was looking at the HY4008 but, think I would need to change the driving resistors? The 3205 is different from the HY4008 in specification.
The inverter I am working on is a HF switching type made about 25 years ago.
All caps are going. The old ones are 3300uf. The new ones from Rubycon are 4700uf at 25v.
Robert
wiseguy
Posted: 02:11am 25 Jul 2019
Was your IRF3306 a Typo - that part is a TO247 package ? The IRFB3206 should be a drop in replacement (TO220) with much better specs than the original IRF3205. It has less than half the on resistance and more than double the pulsed drain current. I have used them in bulk in the past - mainly for synchronous rectification, and cannot remember ever having to replace a dead one. The data sheet is hereEdited by wiseguy 2019-07-27
Cheers Mike
