Forum Index : Electronics : Two very different control boards
| BenandAmber Guru Joined: 16/02/2019 Location: United StatesPosts: 961 |
I don't know nothing about this one it was in a different language ![]() the ad said this oo2 board had totem pole drivers built in ![]() Funny what you come across when looking for capacitors be warned i am good parrot but Dumber than a box of rocks |
I think everybody already looked at this post and didn't have anything to say I was interested in what you guys thought about the one with the totem pole drivers build on to the little oo2 board be warned i am good parrot but Dumber than a box of rocks |
| wiseguy Guru Joined: 21/06/2018 Location: AustraliaPosts: 1329 |
Good find Ben - Looks like the Chinese guys are watching the Back Shed to decide what to come up with next. I wonder if they have also improved the code in their micro-controller. I note that it doesn't have the anti cross conduction transistors now so maybe some of the poorer behaviour has been fixed or improved. The second one probably has Poidas code in it..... If at first you dont succeed, I suggest you avoid sky diving.... Cheers Mike |
| kanchana Regular Member Joined: 08/05/2018 Location: Sri LankaPosts: 56 |
Can you post a link to these? Regards kanchana |
I'm sorry I was just surfing the net looking for cheap capacitors I have no clue where I found them at so I can't post a link I know the O2 board was on AliExpress And you're exactly right Wiseguy the Chinese do read this page and change their stuff accordingly I have a friend that works for Power Jack and he confirmed it with the chokes at least They are supposed to come out with a new board any day now its version 10 and I can't wait to see it I guarantee they have copied most of the stuff off here be warned i am good parrot but Dumber than a box of rocks |
renewableMark![]() Guru Joined: 09/12/2017 Location: AustraliaPosts: 1679 |
Found it here Crafty little bugger, yeah, bet it does have Poidas code. They should have put the 2110's in sockets. $15 AUD BTW if you right click on a page with a different language there is an option to translate to English. (That's Indonesian.) Just noticed it said item has been deleted. Cheers Caveman Mark Off grid eastern Melb |
I'd like to find out some info on the other one the oo2 board with the totem poles drivers on it Just think about this for a minute you guys on here are making the whole world a better place You guys are pushing inverter technology and everyone else seems to be copying you guys They are saving Millions just by reading this page that's my opinion anyway be warned i am good parrot but Dumber than a box of rocks |
| Tinker Guru Joined: 07/11/2007 Location: AustraliaPosts: 1904 |
That right click trick does not work on my computer, no option for translation amongst those shown. Klaus |
| Davo99 Guru Joined: 03/06/2019 Location: AustraliaPosts: 1586 |
If they read here, can I put in a list of suggestions for various little boards I and I know a load of other people would be interested in buying?? |
List any you would like to list be warned i am good parrot but Dumber than a box of rocks |
I use google chrome, it's on that. Cheers Caveman Mark Off grid eastern Melb |
They've came up with another control board ![]() ![]() ![]() be warned i am good parrot but Dumber than a box of rocks |
| Solar Mike Guru Joined: 08/02/2015 Location: New ZealandPosts: 1255 |
Here is the Link and the manual download Mike |
Thank you solar Mike I still don't know how to post links be warned i am good parrot but Dumber than a box of rocks |
Not difficult, see the menu button highlighted with the red circle, click that and a popup window appears; enter the text that will be underlined as the Link; then click OK.... another window pops up, place a copy of the URL address from your web browser and press ok. Cheers Mike |
Thanks for posting the initial post, that board uses a new version of the older EG8010, its now a 48 pin chip running from a 20 Mhz crystal and new software, now called the EG8011, the HBridge driver has all 4 drivers inside it. PWM frequency is now 20Khz. I have ordered one to have a play. Cheers Mike |
Solar Mike I'll give that a try thanks for the education Very interested in your results from your study of this new 002 board If you have the time please post it be warned i am good parrot but Dumber than a box of rocks |
| noneyabussiness Guru Joined: 31/07/2017 Location: AustraliaPosts: 527 |
egs002 compatible Another with totems built in. .. I think it works !! |
Another with totems built in. .. They are learning, however the totems should be near the mosfets, not on the control board, and the tant caps on it are not really suitable for this application. Cheers Mike |
So I'm assuming a thumbs down for solar Mike be warned i am good parrot but Dumber than a box of rocks |
