Local Time 08:57 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Quality of IR2110 Fet DIP14 driver chips
Clockmanfr
Posted: 05:52am 01 Jun 2019
Experiences with Poor quality components.
I have been doing some practical experimenting recently with the OzInverters.
I have had one making slightly more audible noise at the ferrite choke than normal.
I tried to track down the reason.
Over many hours the noise got a higher audible noise. Working in my workshop doing another project.
Then the AC 230va control circuit started misbehaving, a few hours later the toroid started hunting, then it went to a 290vac and I could no longer control the AC output.
Swapped out parts in a methodical way, the 8010 sub board unit, rebuilt the AC output circuit plus a new AC isolation transformer etc etc. Checked the toroid and hardware AC for any shorts etc etc.
Then as a last resort I swapped out the IR2110 driver chips, and hay presto the AC regulation returned, and the ferrite choke is as quite as a gentle bumble bee.
Those IR2110 were direct from China. The new ones I fitted were from RS, I also use Farnell now.
On the outside the chips all looked the same with the manufacturers marks, but obviously they are not.
I know, before you ask why I don't use the other driver chips variants that have been discussed here. Because I like to use what I have, that's if it works.
noneyabussiness
Posted: 06:30pm 01 Jun 2019
I had almost exactly the same experience, ended up with ir2113 from x-on.. maybe try the less " popular " ir2113, usually means less counterfeits.. i can't see any difference other than higher voltage tolerance. .
I think it works !!
