Local Time 08:57 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Mobile power inverter grounding
BenandAmber
Posted: 03:10am 05 May 2019
I am bringing the subject up because I feel it is a very important subject
I would like to hear what some of you guys have to say about it
When you do a internet search on this subject you good lots of different results
And to be honest I just don't trust an internet search 2 something this critical
a ground fault interrupter receptacle will not work without a ground
I know I've been to several people's houses and their washing machine or electric stove wood shock them
99.9% of the time it was caused because of no ground or an incorrectly installed ground
These are problems I do not want to risk in a RV
Any knowledge on this subject would be greatly appreciated
And by the way I know I should know this but I'd rather swallow a little pride and make sure everything is safe
renewableMark
Posted: 04:38am 05 May 2019
this is what I have in my caravan.
Here is another video.
Not cheap but 100% needed.
Hmmmm dunno if it will work on your 60hz 120v USA voltage.Edited by renewableMark 2019-05-06
Cheers Caveman Mark
Off grid eastern Melb
Solar Mike
Posted: 05:56am 05 May 2019
That's interesting Mark, the stand alone inverter outputs have no concept of phase or neutral, the 230 vac output is fully floating just like an isolating transformer. Providing no one has connected an earth (frame caravan) to a pseudo neutral in the caravan switch board, then that seems to me to be pretty safe, any earth leakage RCD or similar device wont and cannot work in this situation.
Cannot comment on USA wiring here.
Mike
johnmc
Posted: 11:58am 05 May 2019
Good Day Mark,
Are you using a inverter in the caravan
if so is the inverter a stand alone unit or ,
is the inverter hard wired to the caravan outlets,with either shore power OR inverter to be selected by a rotary switch.
Another alternative is to use shore power, to charge the inverter battery bank
and then use only inverter to supply power to the mobile unit .
Some commercial inverters also control the maximium shore power that the inverter
takes ie 10 or 15 amps.
cheers john
johnmc
renewableMark
Posted: 12:29pm 05 May 2019
Hi John,
the van is used off grid, out in the bush.
The inverters output goes to the RVD then through to the van wiring.
That is just a small 2800w HF unit, I didn't bother making one for the van.Edited by renewableMark 2019-05-06
Cheers Caveman Mark
BenandAmber
Posted: 04:22pm 06 May 2019
renewableMark and others
I thought about it long and hard
the only way i can see to be able to do it other than RVD
Is some kind of sensor on the ground that reads voltage and if it senses any voltage on the ground it will kick them inverter off
And that's probably how that RVD unit work
Thanks all you guys for taking your precious time and thinking about this subject for me
renewableMark
Posted: 09:16pm 06 May 2019
Actually if you look at the product applications it shows volts 110-240 50/60hz
here
Cheers Caveman Mark
johnmc
Posted: 03:36am 07 May 2019
Good day All
Ben almost all permanent inverter installation in mobile vehicles / boats that I can find
have a single common earth point for both AC and DC cuircuits.
As this is the first time I have tried to reference a web site , hope it is not ballsed up.
check [EMAIL=http://www.projectboatzen.com/understanding-inverter-installations/]
cheers john
johnmc
renewableMark
Posted: 03:48am 07 May 2019
This works better John
Click the hyperlink (globe with paperclip) then type what you want to appear, click ok then paste in the web address.
Cheers Caveman Mark
BenandAmber
Posted: 03:09am 17 May 2019
Thanks renewablemark
That was incredibly helpful I recommend it to anyone who has RV or boatEdited by BenandAmber 2019-05-18
