Local Time 08:58 25 Oct 2026 Privacy Policy
Forum Index : Electronics : recommended inverters
brucedownunder2
Posted: 04:11am 20 Apr 2019
Been following the home built inverter posts for a long time now , very educational.
I considered having a go at construction ,but with my age, health and tolerance ,these days for stuff-up's, I think it wise for me to get something that can easily be given back to be fixed ,if necessary,lol.
I see that Victron,the blue coloured stand alone units advertised on e-bay are fairly well the leaders in their field.
I'm especially concentrating on the 48 volt variety.
I'd be interested in owners or past owners posting comments either way ?.
Thank You,
Bruce
Bushboy
sPuDd
Posted: 09:43am 20 Apr 2019
Bruce,
I've been using the MPPSolar inverters & chargers to run my entire house for about 9 months now. Have had zero issues. Works out of the box. Takes everything I throw at them.
My forum post for my system.
The eBay Seller.
sPuDd..
Edited by sPuDd 2019-04-21
It should work ...in theory
noneyabussiness
Posted: 09:30pm 20 Apr 2019
Bruce,
Ive had 1 of these for years... again works out of the box and handles everything i throw at it.
inverter
I think it works !!
poida
Posted: 12:35am 21 Apr 2019
my Victron experience:
I bought the Victron 3000VA 48V Multiplus back when they were $2,700.
It has very low idle power loss and a 35A charger integrated in the unit.
It ran well, handling continuous loads of around 300W to 1000W, with average loads of 500W. Short periods of 2000W on a daily basis.
The fan ran once power got to 500-600W and it stopped when cooled down.
(not like the Powerjack LF of mine that seems to start the fan then it remains on
no matter how low the load is)
I did not do stupid things such as extreme load tests. It has a high load cut-out and I saw it in action frequently, it works as expected.
It ran for 25 months. I had a 2 year warranty.
This resulted me growing angry enough to resolve to build my own inverter from now on.
The running conditions when failure occurred were nominal room temperature, 500W load, no fan running nor needed, no recent high loads in past week, good battery voltage.
Since repair would likely include cost of freight to and from supplier, plus parts and labour, I thought it's Tear Down Time.
here is the post where I pull it apart
The design uses 2 toroids, powering one under low loads, and then powering both when loads increase. This reduces idle power losses.
The toroid core size is 147mm (OD) x 75mm(ID) x 40mm high.
With 2 of these cores it unsurprisingly required the fan to run when delivering 1500W continuously.
Victron's products are frequently found on boats. I think they used to be made in Holland but mine was made in India. The workmanship appeared to me to be first class.
I now run my house using a self built inverter using an Aerosharp 3000VA toroid, with an extra primary winding I did myself, using the existing 230V secondary. The power board is a 12 HY4008, Chinese made board from Aliexpress, cost about $150US. I add a $20 E core ferrite choke, some wiring and a dual AC output socket.
These run for 6 months or longer.
I would rather build and rebuild my own inverter now.
I costed the Victron as $2,700 and lasting 10 years prior to purchase.
So I am OK with $270/year.
Right now, I am probably coming in a little under that, maybe it's $70/year!!
But I need to be able to rebuild a dead inverter board.
When the Victron died, I bought a PowerJack LF 48V "6000W" unit via ebay.
The seller said in the advertising it was Local Stock.
Evidently, it is OK in Chinese commercial practise to stray from the truth.
After funds cleared, I received the inverter 20 days later, with a consignment note
showing source location as China and destination as my home address.
I became further pissed off when running it. It needed 3-4x more idle power, the fan came on after 10 minutes of 350W and remained on for days.
But I had an inverter. yay.
If you consider a PowerJack, I would fit a primary choke, built using a large ferrite E core. And re-engineer the cooling of the toroid so that air can flow through the transformer, not just over the top and side.Edited by poida 2019-04-22
renewableMark
Posted: 10:37pm 21 Apr 2019
  sPuDd said   Bruce,
The eBay Seller.
sPuDd..
I was very close to buying two of these myself, but got encouraged to build an Oz.
It would have saved a lot of blow ups if I had.
Good to hear you are getting good results from them.
Cheers Caveman Mark
Off grid eastern Melb
brucedownunder2
Posted: 11:37pm 21 Apr 2019
Thanks guys for the feedback ..
Spud, mate, could you send me a pm on the model ,There are heaps of 5 Kw models on that list ,I just want to be sure that I am looking at the correct inverter .
Mine will be stand alone ,possibly not grid connected ,as I already have a grid connected system that returns a 53 cent feed-in to- grid return and would like to keep that .
My system would be , solar -32.3 Kw of 48 volt wired into regulators and charging my batteries.. I'd like something like your inverter that I could power ,on seperate house circuits ,my essential things ,like fries, hot water, lights ,Etc.
So during the day ,most things would be free, but have the grid as a back-up. At night ,use my battery bank and maybe grid if required.
Mark, been following your dramas, would love it if I was younger ,but these days ,sort of at that stage where the kids inheritance will have to contribute ,lol.
Ok, so the Victron is out , and Spud,s idea is the front-runner . Marks DIY is encouraging ,but dunno!!.
anyone have a good second hand unit worth considering ??
Bruce
Bushboy
BenandAmber
Posted: 05:13am 22 Apr 2019
I'm not promoting or saying it will be a good unit
but Power Jack is getting ready to come out with a new one
I here and it's supposed to address all the issues and be a lot better inverter then previous
At least that's is what a guy that sells and repairs them it's saying on his YouTube channel
who knows he should be getting a prototype any day now to try out
last time this happened they went into production on it before he was even finished testing. Gentysolar.com youtube channel is the sameEdited by BenandAmber 2019-04-23
brucedownunder2
Posted: 12:21am 27 Apr 2019
I would like to thank the guys that replied to my post ---what inverter do I invest in ----
Got some very good advice ,. The important point I'd like to make is , Ask many questions on any subject (windmills, solar, electronics' Etc, as that is what will keep this "Backshed" forum going.. I've noticed that a lot of the old guys have moved on ,so ,really, it's up to you new fellas to ask questions and keep the interest ,,the old guys will tune ,but you new guys have got to have a go ..
Typical good new members are Ben and Amber ,,love reading their posts.
Bruce
Bushboy
hary
Posted: 01:07pm 28 Apr 2019
  BenandAmber said   I'm not promoting or saying it will be a good unit
Could you give us link to that youtube channel.
I can't find any Gentysolar channel myself.
Mulver
Posted: 11:51am 29 Apr 2019
  brucedownunder2 said   I've noticed that a lot of the old guys have moved on ,so ,really, it's up to you new fellas to ask questions and keep the interest ,,the old guys will tune ,but you new guys have got to have a go ..
Bruce
My biggest fear is this forum will just disappear one day!
Thousands of post id like to reference for the next 40 years or so..
poida
Posted: 01:25pm 29 Apr 2019
Mulver,
at the bottom of each page is a link "printable version"
so hit that and once loaded, you can then print to pdf.
I find this a good archive method.
It does not retain the uploaded code zipfiles of course.
But it does include the pictures.
I have done this for all the interesting threads here.
renewableMark
Posted: 03:03am 24 May 2019
Bruce I saw something for sale in Qld that might interest you, clean out your inbox its full.
Cheers Caveman Mark
brucedownunder2
Posted: 09:37am 24 May 2019
Yes Mark,
I,be been wiring up the panels ,sort of took longer than I thought.
I wanted to make the wiring neat ,so I had to re,terminate a lot of the panels to dress the feeds in nicely.
Plus a lot of pop riveting of cable clips and splices with heat shrink,Etc.
She,s nearly finished,just a external wall: mounted fuse and disconnect breaker box of tricks ,then the 10mm cables to the regulator .
I see you guys are gearing up for another inverter build with all those pcb,s now delivered,interesting times ahead,lol.
Bruce
Bushboy
BenandAmber
Posted: 04:56pm 24 May 2019
Thanks for the kind words made both of us smile
brucedownunder2
Posted: 11:07pm 24 May 2019
Ben and Amber,
"Thanks for the kind words",
Well, I say"Thanks for your participation in The Back Shed"
nice to read your posts ,along with all the other friends that are having a go.
Please keep us informed as to the "Power-Jack" new model that may be arriving ?
Good luck ,stay safe around those power bits and pieces !.
Bruce
Bushboy
Mulver
Posted: 12:01pm 25 May 2019
  poida said   Mulver,
Thanks Poida! Sorry I missed your reply, thanks for the info I hadn’t noticed that before!
It’s something I’ll certainly be using!
Tinker
Posted: 01:28pm 25 May 2019
Yes, very useful feature. Wish had I known about it instead of using the print screen thing to save a copy for use in my work shed.
Klaus
BenandAmber
Posted: 08:30pm 25 May 2019
I would like to take all the threads of several people on here and print them
So much combined knowledge on here
