Forum Index : Electronics : Turning on 48 v fan using 12v onboard
BenandAmber
Posted: 08:19pm 17 Apr 2019
Using 12v fan out put of egs002 to turn a 48 volt fan on and off
A relay would be simple but can we do better with a mosfet
I think poida the great uses a mosfet
So what would the Circuit look like using a mosfet to turn it off and on
would a mosfet use less power than a relay
How about grounding when using a mosfet and wouldn't the mosfet need a diode and a resistor
Sorry if this is stupid simple
We are not exactly sure how we should do it
We was going to buy a control module but could not find one at a decent price for the DC voltages I needed
We already have 48 volt fans and would like to use onboard temp control
we would appreciate all the thoughts and ideas on this subjectEdited by BenandAmber 2019-04-19
Posted: 09:59pm 17 Apr 2019
Google Images is your friend with simple driver circuits.
This image found in a few seconds when I Googled 'MOSFET motor driver'.
Basically, any MOSFET with suitable S-D voltage and current to handle your fan will work. You need to be ABSOLUTELY SURE that Vgs(maximum gate-source voltage) is AT LEAST 12v(preferably a little more) in your design, or you could blow the transistor up before you get anywhere. Exceeding Vgs will usually destroy the gate and therefore, the transistor itself.
In this image from Google Images, I would also like to see a 100k or so pull-down resistor between gate and source, to keep the MOSFET off in the absence of an 'ON' switching voltage. I also tend to like using a series 1k on the gate just for a bit of additional protection, but then, as there is effectively zero current flowing on the gate unlike the base of a bi-polar perhaps this is overkill.
I would normally recommend my go-to MOSFET - the 14N05, but it's maximum gate voltage is 10v, so you would kill it with a 12v drive, so you will have to find another device.
EDIT: The STP80NE06 MOSFET in the schematic above would work nicely. It has a Vgs of 20v, so you could drive this one happily with 12v.
Link to PDF for STP80NE06 MOSFET... Edited by Grogster 2019-04-19
BenandAmber
Posted: 02:12am 18 Apr 2019
Thanks grogster I really appreciate your input
I have seen many circuits like this online
I just didn't know if it would cause any unexpected problems
like maybe the fan continue spinning after the circuits already turned off and back feeds into the circuit
or introduce noise into the circuit or hundred million other things that could happen that someone less experienced may not think of
People on here are very experienced
have been there done that
I figured I might ask around to see if there was any unforeseen problems
I might run into especially with grounding
And I wanted to know if a relay would do just as good or if it would use a lot more power
A lot of the questions that I asked on here I've already researched
But it's real nice to have somebody that's already been there done that tell you it will be fine
a lot of times they say hey this is a lot better way of doing it
But thanks again for chiming inEdited by BenandAmber 2019-04-19
Posted: 02:26am 18 Apr 2019
Grounding should not be an issue when you are only driving a fan-motor, solenoid or lamp etc. The grounding becomes incredibly important with the MOSFET inverters discussed in the other threads, due to the large currents being switched. You don't really need to worry about fantastic grounding techniques when only dealing with a few amps. That is not to say it is unimportant, but GENERALLY SPEAKING, so long as your ground is present and firmly connected, you'll be fine.
With the inverters, where there can be hundreds of amps being passed, a bad ground and I-squared-R heating can blow things to bits.
Oh, and your other question "would a mosfet use less power than a relay" - yes. Most definitely. A relay 'on' current could be upwards of 150mA or more, most of which is wasted in heating of the coil, but a MOSFET gate 'on' current is microscopic by comparison. Essentially, for most applications, you can assume that the gate current is zero. Or effectively zero anyway!
BenandAmber
Posted: 02:30am 18 Apr 2019
That is exactly the information I was needing thanks again I really appreciate it I will most definitely use a mosfet instead of a relayEdited by BenandAmber 2019-04-19
BenandAmber
Posted: 02:36am 18 Apr 2019
Grogster I just ordered 2 18000uf capacitors for the little China inverter board with only 4 mosfets it came with two 470 UF capacitors do you think it will die or do you think it'll be okayEdited by BenandAmber 2019-04-19
Posted: 02:37am 18 Apr 2019
I guess the only other thing to mention, is that most MOSFET's are static-sensitive - especially the gate connection, as the gap between the gate and S-D path is microscopic, and a static discharge can destroy this incredibly thin insulation between the gate itself, and the S-D path.
So.....use standard anti-static procedures when handling MOSFET's. Once they are soldered into the circuit, the natural impedance of the circuit will generally protect the device - but I still use a wrist-strap just in case with pretty much any modern electronics.
Posted: 02:40am 18 Apr 2019
  BenandAmber said   Grogster I just ordered 2 18000uf capacitors for the little China inverter board with only 4 mosfets it came with two 470 UF capacitors do you think it will die or do you think it'll be okay
I don't know as I don't have that inverter, but I EXPECT that if it came with 470uF caps, that it is designed to run with those OK.
I know nothing about this inverter, so I am probably not the best one to advise you in that respect. Warpspeed etc are the inverter guru's here.
Can you link me to your 'little China inverter board'?
BenandAmber
Posted: 02:43am 18 Apr 2019
That big case fan the one I will be turning on and off with a mosfet I am very impressed with this little board I hope by putting those giant capacitors in there it will help it even more
BenandAmber
Posted: 02:52am 18 Apr 2019
I'm sorry I don't know how to do a link on here the name of the post is little Chinese inverter board
it is one of those little Chinese inverter board you can get for 27 bucks on eBay
I replaceed the Mosfets it came with Hy 4008 and done all the other things that poida told me to do to it
soldered in wire over the traces
I've done right at 2500 watts with it with no problem and it don't complain at all
For 27 bucks on eBay and a few parts good wisdom from poida not too shabby
have you ever heard anyone making their own toroid core me and the wifey have done this and almost ready to wind wire on it will let everybody know how it goes
We wound the Silicon Steel around a sewer pipe and lacquered it with regular Automotive fiberglass lacquer
Poor people have poor ways we'll see how it works out soonEdited by BenandAmber 2019-04-19
poida
Posted: 07:59am 18 Apr 2019
That's one big toroid core.
The nice thing with big cores is the volt/turn ratio.
One this size will be great, you won't need to wind hundreds of turns
just to get to 120V.
We should start a contest. Who can guess the turns needed on the secondary for 120V,
without asking for dimensions. Just use the photo above.
Winner get's nothing much, just admiration.
BenandAmber
Posted: 04:48pm 18 Apr 2019
Hint on size of transformer it's really not that big
it was made to fit in power jack case it's the smaller size swer pipe that we used for mobile homes
but it is quite a bit bigger than the power jack I'm not 100 percent sure after we wrap it if its gonna fit in there
we already have the volts per turn figured out staregazer dont get to guess because he was here when I done the math
So do you guys think going to work out okayEdited by BenandAmber 2019-04-20
staregazer
Posted: 05:11pm 18 Apr 2019
The toroid is the width of a cantaloupe. It’s not as big as what the picture looks. He made it to fit in a power jack case.
BenandAmber
Posted: 05:19pm 18 Apr 2019
A really big cantaloupe
I have a little under an inch to wind the primary and secondary
original Power Jack has lots of room vertically
this one will not it will be very close that way also hope it fits
Staregazer you should go read some of the post about all the different type of microcontrollers
They build and program them for anyting you could imagine
People on here are building and programming and sharing all that information for free
If you have a cool idea thay will help you
Staregazer is the friend I went in on the solar panels
so he has all these solar panels half of the 107 of them that are left so he owns over 50 330 watt panels
has no inverter or charge controller I have been trying to talk him into building a warp speed inverter
And told him there is a mppt charge controller on here being perfected as we speak
All these panels are sitting out in my yard doing absolutely nothing hopefully soon I'll have some of them up on my RVEdited by BenandAmber 2019-04-20
LadyN
Posted: 05:46pm 18 Apr 2019
Wonderful recommendation!
LadyN
Posted: 05:48pm 18 Apr 2019
  poida said   That's one big toroid core.
I look forward to the thinking process!
I know NOTHING about transformers so all your inputs will help me learn
BenandAmber
Posted: 06:38pm 18 Apr 2019
LadyN I'm glad you chimed in
This may be a way of getting a large toroid core on a tight budget
This one that Amber and I made isn't all that big but it's big enough to tell if the concept is going to work or not
I will keep you updated
tinyt
Posted: 06:54pm 18 Apr 2019
Using my old and tired eyes, it looks like the ID is 100 mm (3.9") and the OD is 200 mm (7.87"), roughly. Cannot guess the height.
azhaque
Posted: 02:31am 19 Apr 2019
BenandAmber
Take a look at the spreadsheet and see if it helps.
https://www.thebackshed.com/forum/forum_posts.asp?TID=11134&KW=azhaque&PN=1&TPN=1#130769
azhaque
BenandAmber
Posted: 04:19am 19 Apr 2019
Azhaque that is an absolute must read for anyone who wants to build their own core
that is where I got my ideal from
I read it a long time ago and could not figure out where I read it from
so everything I've done was off memory but it was pretty close
I highly highly recommend anyone thinking of doing this to read the article thoroughly
Thank you so much for bringing up that link I really appreciate it
