Local Time 09:23 25 Oct 2026 Privacy Policy
Forum Index : Electronics : SK-3015 Analog Insulation Tester
dwyer
Posted: 03:15am 18 Mar 2019
My daughter in Japan at the moment and has contact Kaise Corporation to get my Kaise tSK-3015 Analog Insulation Tester repair but unfottunlately told that they are unabe to repair due the age insulation equiment however i dont know anyone in australia can able to repair Kaise so at the moment going send the message back to my daugher hopfully able find a eletronic repair shop somewhere in japan. i brought this $200 Kaise equiment from graysonline about 8 month ago so now my money went down the drain for unknow faulty Kaise insulation tester my mistake. and hopfully try to get it fix soon
Pete Locke
Posted: 04:46am 18 Mar 2019
What is the symptom with it? A quick Google search for Kaise tSK-3015 Analog Insulation Tester didn't bring anything up. Correct name and model?
Pete'.Edited by Pete Locke 2019-03-19
dwyer
Posted: 05:26am 18 Mar 2019
Sorry my misspell Kaise SK-3015
Boppa
Posted: 07:33am 18 Mar 2019
Didn't have any luck with contacting the Australian mob???
dwyer
Posted: 10:00pm 19 Mar 2019
  Pete Locke said   What is the symptom with it? ok both 2 mm test lead got ace on the tip so someone accidentally put on ampere setting instead voltage setting and no luck finding Kaise dealer or support service in Australia maybe is good thing is a hammer and throw nice Kaise tester in the bin Problem is solve.
