Local Time 09:23 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Need help testing Transformer
BenandAmber
Posted: 12:20am 21 Feb 2019
I got my 52 lb Transformer in the mail today I powered it up using a 1 20.3 volts out of my wall socket I put a small old-style light bulb in series on one leg not sure what the wattage is on the light bulb but on the output low side it put out 18.68 volts one the light bulb I got a reading of 88.3 this is right after the light bulb in series on one side and the other side connection Mains to Transformer so the voltage out of the wall was 120.3 the voltage after the light bulb was 88.3 the output on the low side of the Transformer was 18.68 the amperage reading was 0.06 I had a small jumper hooked up to by pass light bulb when I tried to bypass it made big spark so I did not do it I would greatly appreciate any input I could get from the experts on here and I thank you very much for all the helpEdited by BenandAmber 2019-02-22
LadyN
Posted: 02:22am 21 Feb 2019
OK. I am very exicted to see you going so fast.
AWESOME!
First, I really recommend putting in spaces and returns/enter key in what you type so it's easy to read for everyone.
Once you make it easy to read, people will help you more. I used to have the same challenge years ago and someone took time to teach me this so I am trying to do the same. Hope you like it :)
I took the liberty of doing this to your above post:
Did I reformat it correctly and convey your post properly? It might be possible things got lost in translation so please don't get upset but tell me what I did wrong and I will try again.
LadyN
Posted: 02:42am 21 Feb 2019
Now, before we proceed, you must understand that at these voltages and currents, you WILL kill yourself and anyone around you including setting things up on fire if you make ANY mistakes so make ABSOLUTELY sure to run by any and all plans you have by an electrician before you plug anything into mains.
I also highly recommend either buying or making an isolation transformer.
If you are interested, we can make an isolation transformer together and the people here will help us do it, so let me know what you think. An isolation transformer with proper safety features reduces somewhat but does not make 0 the chances that you will kill yourself and anyone around you.
I also highly recommend starting off with lower voltages and currents first and then once you understand everything, make a higher voltages and current version.
LadyN
Posted: 02:49am 21 Feb 2019
OK, now you must start drawing things.
As they say, pictures are worth a thousand words, so let me draw, very roughly, what you said:
Mains L -----[Bulb]-----[Transformer]----- Mains N
It would have been better if I drew a picture.
The two wires coming out off the top of the transformer is the secondary winding (if it has only one secondary winding).
I am assuming you measured 18.68v across this transformer secondary winding
Did I get ALL of it right? If I am wrong in even one thing, you have to tell me.
In that case:
Mains provide 120.3 volts
If the voltage after the light bulb was 88.3V, it means there was a drop of (120.3 - 88.3) = 32V across the bulb.
This also means that the transformer saw only 88.3V of the possible 120.3 volts. Check if this is the case.
Since you got 18.68 out of the transformer secondary winding after feeding it 88.3V at the input, it's a 88.3/18.68 = 4.73:1 step down transformer. My guess is that if you connected it directly to mains (DONT DO THAT YET!) you would have got 120/4.73 = 25.37V.
We need more information to help you:
1. What's the cold resistance reading of the bulb? IF you safely can, measure the warm resistance reading of the bulb by connecting it directly to the mains and measuring the ampere. Make sure the meter you are reading can go upto 15A and that it has a working fuse
2. What's the specification of the transformer? For example do you have a picture of the eBay listing? Or do you have a link to the product page? (your eBay purchase history should have this information)
LadyN
Posted: 03:12am 21 Feb 2019
I have to eat dinner and then go to sleep soon but I thought about this experiment and have two questions myself:
i. Why did you get a reading of 0.06A from the transformer output? Since there was no load connected, you should have got 0. Does this mean 0.06A is the current consumed by the secondary winding itself?
ii. IF you shorted the secondary winding, would 0 volts appear across the transformer? Probably not because the transformer is not ideal and has some loss, but how much would that be?
iii. Consequently, would the bulb brigten up when the secondary winding was shorted? By how much visibly (given our vision is logarithmic not linear)?
I will wait upon the Gurus on this forum to provide insight
BenandAmber
Posted: 09:34am 21 Feb 2019
You done a very good job ladyN
I am not very good at writing
I am on a phone have no PC
I apritiate the tips
U answered my question ty
I couldn't find my multimeter so
I stuck my tongue to the output of the Transformer
to make sure it was getting voltage
you no kind of like you do on a 9 volt battery
I'm just kidding.
you did a very good job and I appreciate your concern for me
I am a electrician so I got myself to help me lol
my carelessness in the past has got me a couple times
thank goodness the good Lord above was looking out for me
had a plan for me still yet
cuz I'm still here
but I do have a great respect for electricity
I really appreciate you doing the math for me sometimes I just can't get my brain to work no matter how hard I try
I have my good days and I have my bad days bad days
I get lost in my own hometown on bad days but that's neither here nor there
You answer my question and I am very grateful
you are very smart and awesome
thank you and by the way I'll try to quit doing run-on sentences you gave me some good advice and I'll try to take it if I don't I'm sure you'll let me know LOLEdited by BenandAmber 2019-02-22
BenandAmber
Posted: 03:40am 26 Feb 2019
Would this Transformer be good for a inverter project
it is very heavy
I tested the no load current on it it was 0.05
I tested it with volt metter clamp with no load on secondary
you can leave it plugged in for days and it won't even warm up a little bit
Would anybody have a guess to how many watts it may be
the two to the left are 3000 va together out of smart apc ups are thay good for inverter
I would appreciate any and all feedback on this subject thanks everybody Edited by BenandAmber 2019-02-27
azhaque
Posted: 07:18am 26 Feb 2019
BenandAmber,
The transfo looks a little beat up with possible shorted turns.
To determine the usefulness of this for an inverter, please measure the physical size of the core, particularly its center leg plus the size of the stack, for an E-I or E-E core.
I have an Excel sheet in another thread on this forum which helps to calculate the parameters of the transfo, by putting in the physical data in the Excel sheet's designated cells. If you don't have a PC, just copy the data here and we can do the calculation.
azhaque
BenandAmber
Posted: 10:09pm 26 Feb 2019
This is the Transformer I'm trying to figure out the wattage
Or what the core is capable of
Thank you for your time
BenandAmber
Posted: 10:47pm 26 Feb 2019
This is a Transformer Amber was working on
the question here is
She stacked for Transformer cores together and bonded them with epoxy
the four Transformers cores where 250 VA a piece
by stacking them this tall will it hurt the performance of these Transformers
if so how
second question is do you add the 250 v a four times to come up with the new VA
or will it be different
we have both research this and can't get no answers
we found other people asking the same question but no answer
thanks for your time I really appreciate itEdited by BenandAmber 2019-02-28
BenandAmber
Posted: 11:02pm 26 Feb 2019
This is like the transformer cores she stacked together
They are made up of incredibly thin layers
Sorry guys I still haven't figured out how to put two pictures together on the same post
I would like to finish winding this Transformer for the little Chinese eBay board
I am debating between this one
the square one above
or maybe some smart Apc UPS Square Transformers I have I think the toroid might be the most efficient
If you have an opinion on this please let me know I would appreciate all opinions
Thank you for your timeEdited by BenandAmber 2019-02-28
BenandAmber
Posted: 03:38am 27 Feb 2019
I left out one of the window measurements in the first pick
I've been searching all over the internet I can't make heads nor tails of how calculate this va
If anyone knows of a tutorial or something I can read somewhere that simple for someone like me to understand
I would really appreciate it
I know the width times the depth equals core area or something but that don't give me VA
Thanks for your timeEdited by BenandAmber 2019-02-28
tinyt
Posted: 04:48am 27 Feb 2019
Found this transformer tutorial with spreadsheet calculator
Tried your transformer width and stack height, it gave me a VA of 871 at 60 Hz. I don't know if it is accurate. Not yet finished reading it.Edited by tinyt 2019-02-28
BenandAmber
Posted: 02:27am 28 Mar 2019
Tinyt thanks for the link
