Local Time 10:03 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Resistor Arrays.
Phil23
Posted: 11:14pm 12 May 2018
Hi All,
I got a collection of LED bar graph modules a while back.
The DIL type with 8 separate LEDs in each.
Figured I'd be able to just grab some 100 Ohmish resistor arrays to make them easy to implement.
Was figuring arrays with 1 common pin & 8 "R" pins would be an easy find...
Tore some hair out & gave up.
Lots of different matrix's popped up, but what I was after seemed to elude me.
Can anyone point me in the right direction?
Was using searches like "SIL resistor network or array" but getting the wrong hits.
Phil.
noneyabussiness
Posted: 12:04am 13 May 2018
What sort of power rating you looking for? ? Each or total??
I think it works !!
oztules
Posted: 12:20am 13 May 2018
try this
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.XRESISTOR+ARRAY+4309R-101-101.TRS0& _nkw=RESISTOR+ARRAY+4309R-101-101&_sacat=0
.......oztules
Warpspeed
.Edited by Warpspeed 2018-05-14
Cheers,  Tony.
oztules
Posted: 12:22am 13 May 2018
https://www.ebay.com.au/itm/8pcs-4309R-101-101LF-Bourns-Resistor-Networks-Arrays-9pin-100oh/263506002516?hash=item3d5a2e 8254:g:p~YAAOSw05taipd3
the last did not work.
search for 4309R-101-101 .
......oztules
Edited by oztules 2018-05-14
Warpspeed
Posted: 12:24am 13 May 2018
https://www.ebay.com.au/itm/pack-of-20-or-200-8-resistor-9-pin-SIL-100R-2-resistor-network-9E101G/391956729672?hash=item 5b42710f48:m:mEzv5NppN930YC0mUTh08xg
Cheers,  Tony.
oztules
Posted: 12:27am 13 May 2018
Cheaper even from England than Australia..... this place is the pits for electronics.
.......oztules
Phil23
Posted: 02:12am 13 May 2018
Thanks for that.
Now that I can link to a Data Sheet, I can see that what I want is termed "Bussed Resistors" on page 2 of the data sheet.
That was the bit that was stumping me; the various configurations within the packages.
Phil.
Warpspeed
Posted: 05:39am 05 Jun 2018
These things are known by a great many different names, which makes finding something frustratingly difficult.
At least on e-bay, try using search terms like "4K7 9 pin" seemed to work.
Just ordered a big bag of these beasties myself.
Cheers,  Tony.
Phil23
Posted: 10:38am 05 Jun 2018
  Warpspeed said  Just ordered a big bag of these beasties myself.
By big bag, do you mean a bag of mixed values?
If so wouldn't mind a link to the listing.
Phil.
Warpspeed
Posted: 04:49pm 05 Jun 2018
All the same value, but pretty cheap.
https://www.ebay.com.au/itm/50-PCS-A09-472G-4-7K-ohm-4-7KR-4K7-8-Commoned-Resistor-Network-Array-9-PIN/301232134017?ssPa geName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649Edited by Warpspeed 2018-06-07
Cheers,  Tony.
