Local Time 20:43 24 Oct 2026 Privacy Policy
Forum Index : Electronics : Panel Meters Article
SparWeb
Posted: 06:46pm 08 May 2008
I was looking at the panel meters here (http://www.thebackshed.com/windmill/articles/PanelMeter.asp ), and found the article interesting.
What I don't get is why aren't you using a LM7809 to power the displays? Why go to 5V just to bring it back up to 9?
That inverter sure looks like something I should pull off a few network cards I have lying around, though...
Steven T. Fahey
Posted: 08:58pm 08 May 2008
Hi Steven
The inverter is used because the displays need a isolated power supply. The inverter has a input voltage requirement of 5 volts. If we feed it the full battery voltage ( 12, 24, etc ), it will die a very quick and smelly death.
GlennEdited by Gizmo 2008-05-10
