Forum Index : Windmills : Hertz meter
| Ben Newbie Joined: 10/08/2007 Location: AustraliaPosts: 18 |
Can anyone tell me wher to get a Hertz meter so I can measure the RPM on my 3 phase f&p mill. |
Are you anywhere near a Dick Smith store? Here's a cheap multimeter with a frequency meter that will work for what you want. http://www.dse.com.au/cgi-bin/dse.storefront/47ece68809b6bd6 4273fc0a87f9c077f/Product/View/Q1456 Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Tinker Guru Joined: 07/11/2007 Location: AustraliaPosts: 1904 |
Has anybody worked out a way to use the original hall sensors on the little board that are inserted near the F&P stator coils? I tried to trace out the related parts on the PCB where the sensors plug in but that did not make a lot of sense. These sensors would be a neater way to measure RPM than trying to interpret AC frequencies IMO. Tinker Klaus |
