Local Time 20:10 24 Oct 2026 Privacy Policy
Forum Index : Windmills : F&P Electronic Dynamic braking
     Page 1 of 3
DaveP68
Posted: 07:31pm 05 May 2017
Have been doing some research into the possibility of have a form of automatic electronic braking in high winds.
There has been a lot of previous discussion of F&P stators operating above 500 RPM the core becomes saturated with the torque curve dropping off. With furling set up correctly this can keep things under reasonable control. In very stormy conditions this may not all work out so well so some form of braking should be considered.
F&P washing machines made between 1993 and 1998 had a 300 W peak rated dynamic brake function. A safety feature used if a lid was opened at max spin of 1000 RPM it could bring a load of bowl + clothes 20 kg's max to a stop in less than 4 seconds. They type of stator used was the 80s on all those machines.
For a day job I repair these boards and need to activate this function as part testing the motor control module.
Here is a photo of a modified module used as a load at 900 RPM 1000 W of energy being extracted from the stator.
The proposal I have is to use a capacitor doubler to extract maximum current out of the stator before the core becomes saturated. The trick is to extract maximum power from say 2 stators on the same shaft when a peak RPM is reached. If more power is taken from the shaft than the blades can deliver we go into a lower TSR range. That way a controlled shut down can be done before the wind gets too strong.
This requires some fine tuning in terms of a workable system, but from some testing I've done with one stator it should be possible.
With this separate cap doubler (one for each stator) is used for braking only when running in over drive mode on a 36 pole 4x 3p Delta I get 72 VDC 16.4 Amps 1.18 kW @ 550 RPM. Thing is the shaft power required to drive the stator is >2 kW. That is from just 1 stator! This same stator when not used in braking mode would normally be charging a 48 VDC battery system. The same system can be set up for a 6x 2p Delta, with the brake operating at 48 VDC 24.6 Amps peak at brake application.
Taking more power from the shaft than it can deliver will push the blades into stall region slowing them down by dropping the TSR to below 5. The maximum current and voltages of course would reduce and have to be carefully controlled to slow the blades down.
This way the blades can brought to almost stopped state (tuning slowly if wind is strong enough) if set up correctly. The brake would release when the stormy conditions have passed so to speak. Yes you would not be making power while storm passes but wind turbine stays safe
This is only in a concept form at present so no working system yet.
DavidEdited by DaveP68 2017-05-07
Hatman
Posted: 05:56pm 06 May 2017
Hi, David I'm looking at dynamic braking for my system as well, (8xf/p) I was thinking that maybe for me a way to do this is to use the dump load or a voltage from the DC side of the rectifiers at a point before saturation to trigger a short on the AC side of individual stators and using different DC voltage to trigger different stators increasing braking but still producing charge from the un triggered stators do you think this is a viable thing?
DaveP68
Posted: 09:17pm 06 May 2017
Hi Hatman
You can't apply a short circuit to an F&P stator as it just puts them directly in saturation. From tests I've done on any version of F&P stator, saturation happens below 60 RPM on a short circuit condition (AC or after rectifier DC side).
What is outlined above, is that 'Electronic Dynamic braking' must happen under controlled conditions. By diverting the maximum amount of energy into a load that takes more power out than what it can deliver efficiently is the key. It causes the stator to take 'as you would say' the maximum Nm of torque from the drive shaft. This puts turbine to a stalled sate to slow it down in a controlled way.
From what I've seen on this website, no one has been able to do Electronic Dynamic braking on an F&P wind turbine to date. Anyone is welcome to correct me if I'm wrong on this one, but it requires a complete understanding of the F&P stator operating perimeters to do so. I have that understanding, as deal with them every working day.
DavidEdited by DaveP68 2017-05-08
Warpspeed
Posted: 03:58pm 11 May 2017
I think its going to be extremely difficult to achieve sufficient braking in a nice simple way using just a standard bare F&P motor and no microprocessor.
A very effective electromagnetic eddy current brake can be made with just a plain aluminium disc and a dc electromagnet. The faster it spins, the more braking torque it can produce (for a given applied electromagnet strength).
https://en.wikipedia.org/wiki/Eddy_current_brake
Couple that up to the dc output of your F@P rectifier.
Cheers,  Tony.
govertical
Posted: 05:15pm 11 May 2017
http://www.circuitstoday.com/wp-content/uploads/2009/09/Over-Voltage-Circuit-Protection.jpg
https://youtu.be/Eg3mL_NJSkM
Hi, I found and manually tested the above circuit. D5 brake down voltage triggers the SCR. When the AC goes to zero the SCR turns off and the circuit resets. I am not sure if this is dynamic braking, if you need a parts list I can provide a list of the parts I used.
just because your a GURU or forum administer does not mean your always correct :)
DaveP68
Posted: 07:30pm 12 May 2017
Hi to you both and thanks for the feedback.
  Warpspeed said   I think its going to be extremely difficult to achieve sufficient braking in a nice simple way using just a standard bare F&P motor and no microprocessor.
Think you're mostly correct in what's stated above.
  govertical said   Hi, I found and manually tested the above circuit. D5 brake down voltage triggers the SCR. When the AC goes to zero the SCR turns off and the circuit resets. I am not sure if this is dynamic braking, if you need a parts list I can provide a list of the parts I used.
I also like your idea govertical, but being AC needs to be a 3 phase input for the F&P stator operation. Let me know some component values anyway as got lots of bit lying around the workshop may able to try it out.
Understanding these F&P stators, especially them wanting to give a max current regardless of RPM/Volts range gives me a clue for a simple control circuit. It could be built without the need for a microprocessor.
How this breaking function coukd still work on a stator(s) output is by having a trigger point from a anemometers wind speed output. Once this threshold is reached (say 12-14 m/s) the braking circuit would take maximum current from the stator(s). This max current draw would be kept constant (just below saturation point) with the voltage dropping down. The RPM would decrease due to the blades being pushed into low TSR range.
The stator(s) can give maximum current at less than 60 RPM. The brake still taking maximum current could stay on due to the anemometer output showing a trending high wind speed over say a timed period. Once the winds reduce below a set threshold for certain time period the electronic break would be released.
Tony I do think your above idea has far more merit, as it's very simple to build and can be electrically activated from the F&P stator(s) rectifier output.
One extra thing to consider though. The wind still putting lots of force on the blades when the RPM drops to a low level "with brake on" the power feed from the stator(s) would drop off. This would need to managed properly as the blades RPM would start hunting. This is due to brake starting to release in low RPM, blades speed up a bit, brake on again etc etc. Probably a simple thing to overcome though as an equilibrium point should be reached at some point.
Reason I bring this point up is on train which this system is used on, the power from traction motors is shut off. Then the braking system only needs to act on the inertia of the train cars still moving to bring them to a stop.
I just like the concept of having the brake function as part of the stator(s), but this could prove wishful thinking on my part
DavidEdited by DaveP68 2017-05-14
Warpspeed
Posted: 08:13pm 12 May 2017
All the excess power has to go somewhere.....
Burning up the small coils in the F&P is not going to be very productive.
Rapidly stopping a spin dry load only produces a short once only heat spike which may be tolerable.
But like the terrifying brake fade in your vehicle on a very long steep hill, using dynamic braking continuously is a very different thing to a one time panic stop.
This is where an eddy current brake really shines. It has a significant exposed surface area that will easily dissipate kilowatts of power continuously if it has a sufficient amount of cooling airflow. Not too much of a problem for us in a storm.
I have at home a 400 Hp continuously rated eddy current dynamometer that has a pair of 330mm brake discs.
Larger units are used to brake fully loaded semi trailers and buses, and even bullet trains.
Its just like a disc brake, but without the pads or a friction surface. The "caliper" is an electromagnet that puts braking heat into the disc electrically through circulating eddy currents that may be hundreds or thousands of amps.
The difference is that a friction brake has almost constant braking torque at any speed, including fully stationary.
An eddy current brake produces more braking torque the higher the rpm.
So even without a proportinal control system, an eddy current brake would significantly reduce turbine rpm by working much harder at higher turbine rpm when switched in.
Cheers,  Tony.
govertical
Posted: 08:15pm 12 May 2017
R1 any high wattage load
SCR1 and SCR2 MCR8SNG
D1, D2, D3, D4 HFA 08TB60
D5 select a zener with a high brake down voltage, you can connect a few in series to get a higher brake down voltage.
Hi, you can make 3 circuits, one for each phase. Once the circuit triggers there is a combined load from R1 and the (I squared R) loss at the stator. Edited by govertical 2017-05-14
DaveP68
Posted: 12:22am 13 May 2017
  Warpspeed said   All the excess power has to go somewhere.....
Have you ever heard of an F&P stator burning out? To my knowledge of how they work it will never happen if run in it's designed operating envelope. This is exactly the point I was trying to get across with the train slowing down, it's the same as rapidly stopping a spin dry load. We are talking cross purposes again I'm more ahead in my thinking than perhaps you think I am. Not trying to be critical here Tony but just a bit of deja vu coming back to from another recent topic.
When going into controlled shut down, this is done over a period of 5 to 10 seconds with the blade RPM taken from 600 RPM down to below 100 RPM. This is achieved by initially putting the blade into a "Tip Speed Ratio" (TSR) of lower than 5 effectively putting them into partial stall condition. When the blades are in this stalled operating region the amount of torque on the shaft drops off a cliff. Please refer to the power coefficient curve below relating to "TSR" with formula relating to RPM.
So the initial braking application will take a lot of energy to bring the blades under control and down into that partial stalled region.
I hold a pilots licence which means I understand stall condition very well, if I didn't could have killed myself and my passengers. I formally worked in aviation sector which gives me a bit of understanding of this stuff.
There is practically no difference between the amount of lift that a wing "generates" and the amount of power blades can feed into a shaft. This is shown at the top of "that nice curve" above. Stall condition once it's reached (not desirable in an aircraft) is exactly what we want to use to bring the blades electrically under control.
When the RPM is under control (below 100 RPM in stalled condition) the current in the stators will be at a manageable level, so no excessive heating of those small coils!
Like I said above your idea does have lots of merit and I like it Please also consider I have put good amount thought put into a concept before it is published.
  govertical said   R1 any high wattage load
Thanks govertical will check what bits I have on hand and try out your circuit just for the fun of it to check what it does. Edited by DaveP68 2017-05-14
Warpspeed
Posted: 12:49am 13 May 2017
I was a student pilot once myself, passed my BAC (basic aeronautical knowledge) logged quite a few hours solo too, then decided I really could not afford to do it as well as buy a house. The house won, and I have not flown since. Still have my pilots log book around here somewhere.
Anyhow, you are quite right about putting the blades into a completely stalled condition.
Cheers,  Tony.
DaveP68
Posted: 01:26pm 13 May 2017
Got my Private Pilots Licence just over 20 years ago while I was working at Air Traffic Control known as Airways here in NZ. So didn't flying for a living, but did clock up quite a few hours.
Here's a picture of me on the job taken in the late 90's.
Do miss working in aviation, as it's very structured in the way it operates at the sharp end. But in Feb 2000 the domestic operations were centralized in Christchurch and I didn't want to move there so took redundancy.
They have earth quakes in Christchurch, so putting all their eggs in one basket with only ONE centralized control center can shut the whole domestic operation down. Planes stay on the ground when this happens for up to 4 hours. While this is happening nothing moves from Auckland to Wellington and other cities (International airspace control is still in Auckland). In the last 6 years they've had at least 3 major shut downs of our domestic airspace for a few hours at a time. Airlines and Airport companies put pressure on Airways NZ to improve the system. They have now made the wise decision to bring the upper North Island airspace control back to Auckland. Back to how it was when I worked there.
I probably wont go back as get more time off with what I do now and lots less stress.
Have a similar story to you with the flying being an expensive hobby. I brought a house with the help of a large redundancy payment mentioned above 17 years ago and haven't done much flying since. The house always wins so to speak Edited by DaveP68 2017-05-14
Warpspeed
Posted: 01:44pm 13 May 2017
[quote] I brought a house with the help of a large redundancy payment [/quote]
That is definitely the best way to do it.
For me it was my savings from two year long expeditions to Antarctica. Nothing to spend money on down there, and the pay was good.
By that time I had not flown for three years, so would have had to begin my training all over again.
I could not fly now because of medical problems. I always had trouble clearing my ears of pressure during descent, and I have gradually lost my hearing to the point where I am completely deaf in one ear and have lost 80% hearing in the other.
So flying and Amateur radio are no longer hobbies I can really pursue.
Cheers,  Tony.
DaveP68
Posted: 03:29pm 13 May 2017
Interesting story Tony with two year long expeditions to Antarctica. Yes that would allow you to save up a good deposit. There are far to many things to distract or tempt us to fritter away that hard earned money when at home base. Sorry to hear that the hearing is almost gone.
My late Uncle was a scientist with a PhD in biological physics. He did 2 trips to the South pole in Antarctica, not many get to go there. He told me a story of returning to NZ from Antarctica and how you need to clear immigration/customs at Christchurch having been out of the country. The chap in front of him put his occupation on the arrival card as Forestry researcher (was one). The immigration officer observing that he was a Forestry researcher arriving back from Antarctica asked what he was doing down there. He without blinking an eye said "We'll we went down there, had a dam good look around and we're going advise them not to ago ahead"!! Immigration officer goes very quiet, gives back his passport next person please Stupid question...
Been to 51 countries, but not Antarctica. You have too get along with others if you're there over the winter period as there was no way to leave?Edited by DaveP68 2017-05-15
Warpspeed
Posted: 03:58pm 13 May 2017
Ah yes, the Americans have it pretty easy at McMurdo, fly in, fly out, unlimited water and power (they have a small nuclear reactor) and a trip to "Little America" right at the pole would have really been something.
Their bases are run on military lines, with rank, and the support staff would all have been US navy personnel on assignment. Plenty of civilians there too of course.
With us Aussies it was a whole lot different. Only fifteen of us rat bag Aussie civilians, and we get to unload the ship ourselves, diesel power only, so life for us was a lot more primitive in a great many ways. No flush toilets, and showers and washing clothes was pretty restricted.
I was able to save more than the deposit, in fact I was able to pay fully in cash.
Back in 1972 15K was a hell of a lot of money.
The same block where I still live is now probably worth almost one hundred times that original amount.
I could not imagine a job where two years pay would buy into a similar location these days.
Edited by Warpspeed 2017-05-15
Cheers,  Tony.
DaveP68
Posted: 12:34am 14 May 2017
That's good you ended up paying cash for a house even back then. I call the housing market here in Auckland a Ponzi Scheme, Bernard Madoff set the standard!
I've been mortgage free for about 10 years now so never had a big one to begin with. The only job I can think of that you pay cash for house after 2 years these days in Auckland would not be legal...
Warpspeed
Posted: 11:20am 14 May 2017
Back on topic...
I have been giving some thoughts to this dynamic braking problem as applied to an F&P which is really a synchronous three phase motor/alternator.
Its very different to dynamically braking an induction motor because this has the permanent magnets.
What I expect should work would be a three phase rectifier (which we already have) to generate a dc voltage roughly proportional to rpm, followed by a fairly high constant current load.
The trick is to hold the braking load current high enough to get sufficient braking torque, but not so high it saturate the magnetic circuit. We need to control the load current so that it stays constant, with a rapidly falling dc bus voltage, as the alternator rpm is rapidly pulled down.
That could be a simple hysteric controlled load that switches itself on and off (PWM) around some desired set braking current. If the current falls, the load goes back on. As it rises it is switched off. It self oscillates around some desired mean braking current, holding it almost constant during deceleration.
If you have a circuit diagram for the F&P, it may already show something like that.
Cheers,  Tony.
DaveP68
Posted: 11:56am 17 May 2017
Hi Tony
You read my mind. Yes already have the basic circuit which currently works in the voltage trigger mode (40 - 480 VDC). Just need to use a spare LM393 op amp on the boards I have to amplify the small voltage across a current sense resistor. This can then be put into the same variable value comparator input that I currently use for the voltage trigger point. This circuit works by as you say by the same hysteric controlled PWM.
That Blue coloured board in the photo has all the parts on it to perform this function. Just need to make the resistor a lower value and make sure the IGBT device can handle the peak current. The current sense resistor will need to be about 0.01 ohms and rated at 10 W.
What do you think?
DavidEdited by DaveP68 2017-05-18
Warpspeed
Posted: 12:17pm 17 May 2017
You may need a fairly decent electrolytic across the dc bus to minimize the worst of the wild voltage swings, as the load comes on and off, but that is the general idea.
Only way you could do much better than that at lower rpm, would be to energise the original F&P motor drive fets to slow astern. I have no real idea how an F&P actually does all this, even though I have one in the laundry. Its never missed a beat so I have never had the covers off.
Cheers,  Tony.
DaveP68
Posted: 09:43pm 14 Jun 2017
  Warpspeed said   Only way you could do much better than that at lower rpm, would be to energise the original F&P motor drive fets to slow astern. I have no real idea how an F&P actually does all this, even though I have one in the laundry. Its never missed a beat so I have never had the covers off.
Have been thinking of doing some more work on this Electronic Dynamic braking and I think you're idea to energise the stator is great to get the RPM down to a minimum amount. This can be done by firing an opposing waveform back into the stator. This can be a closed loop controlled system by making use of the RPS unit (Rotor Position Sensor) that sits on the side of the stator.
Refer to the white device that is sitting at the 2 o'clock position on the stator in the above photo. In this setup it's only going to be used to measure the exact operating RPM of this stator.
DaveP68
Posted: 12:50am 21 Jun 2017
For those that are interested in following this topic on F&P Electronic Dynamic braking, have now got the circuitry working that can perform this function.
Doesn't require any complex electronics like a microprocessor, just a bunch of op amps!
Will publish the circuit diagram once I've done some fine tuning to how it will operate in the real world. This will soon be tested out on a real wind turbine.
This circuit can be adapted for use on basically any PMA including an axial-flux unit(s).
Have a furling system as a backup is a wise choice, so not trying to say that that function has been superseded.
Just like the concept of a fully automatic system that requires no manual input from the end users perspective.Edited by DaveP68 2017-06-22
     Page 1 of 3
