Local Time 04:44 25 Oct 2026 Privacy Policy
Forum Index : Windmills : stacking VAWTs laterally
wllewellin
Posted: 02:18am 04 Feb 2008
I am thinking of linking 3 or more Savonius VAWTs laterally by means of pulleys, anyone tried this?
Dimensions would be 1.5 m high and about 70cm wide for each rotor.
Gill
Posted: 11:20am 04 Feb 2008
G'day wllewellin,
It's good to consider options outside the square at times, though in this case I suspect you'll have no takers.
The first problem with this idea is the losses due to the transmission driving the three at the same rpm. And they will be driving rather than just synchronizing as the air flows will differ between the three in that configuration.
In addition to this comes power losses when the wind comes from an angle and shadows those behind, unless you intend to do away with one of the sav's key advantages of not requiring a wind seeking mechanism?
You offer no sound reason as motivation for using such a configuration as a benefit to offset the losses. Regardless of the dimensions, in my opinion, this system is a non starter.
But perhaps you can convince me otherwise?
Cheers Gill _Cairns, FNQ
Tinker
Posted: 02:08pm 04 Feb 2008
Funny you should post that question, I was thinking about the very same subject but with a slight twist to it.
What I dreamed up is two of these turbines geared via a large cog to a central shaft in between. The generator is on the central shaft. The two turbines would turn their way round the central shaft cog if that shaft was locked, to explain the mechanical action.
What I am assuming is (all theory here) that the two savonius turbines would come to some equilibrium with the present wind direction and start driving the central shaft.
No problem for wind direction seeking here.
No problem with the big mechanical guying of vertically stacked savonius.
Less visual impact, it might be interesting to watch the counter rotating turbines.
But, is my theory right??
One day I am going to build a model to see what happens, I got some plastic cogs out of an old laser copier and a tiny PM motor to check if two make more power than one .
Klaus
Klaus
TugHill
Posted: 07:33pm 04 Feb 2008
Hey Every one.
Why not make just wider (more torque) and it will drive a bigger genset?
I am currently considering a similar setup,I have lots of gusty wind and lots of shade trees.
Larry
KiwiJohn
Posted: 02:30am 05 Feb 2008
If one really wanted to build such a thing I would suggest not belts but bicycle chains and incorporate the rear wheel coaster hubs so that if any are so sheltered as to not be contributing power they will not be loading down the others either.
An easier way to obtain the same thing, that is the coupling together a number of small VAWTs, might be to put a generator on each one and combine their outputs.
solarwind
Posted: 01:04pm 05 Feb 2008
I have to agree with you on this method because in this configuration, there will be no mechanical interference between the turbines and with proper diode steering, each alternator will be effectively "isolated" from the other so as to not act as a load for the other.
You don't have success until you've tried it!
