Forum Index : Windmills : 7 phase F&P Rotor coggings
Storm![]() Regular Member Joined: 12/09/2005 Location: AustraliaPosts: 43 |
Do the 7 phase 2 pole reconected stators work using the old 56 magnet rotors or does it need the new rotors? I reconnected as instructed and installed my old 56 mag rotor and found cogging to be higher than before the reconnection, is this normal? I don't have a new rotor yet so I couldnt test it, any suppliers of the new rotors in Adelaide? |
Hi Storm. Yeah the 7 phase conversion only works if you use the new 48 magnet hub. Basically we have miss matched the stator and hub, and the 7 phase conversion fixes this miss match, with the big plus of no cogging. I dont know of any suppliers in Adelaide, but any white goods agent should be able to tell you the local repair agent for F&P machines. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
