Local Time 04:19 25 Oct 2026 Privacy Policy
Forum Index : Windmills : 80SP in Star
FandPwithPVC
Posted: 04:48am 27 Nov 2007
Hi All This topic is only for those people with test benches or towers with F and Ps on them .
PLEASE NO THEORIES
The test results below are on a 24 volt system and were tried in a Delta circuit also. They are from the bench.
216/220 RPM with 3 times 216 uF Just starts putting out
250 RPM with 3 times 216 uF 5.0 Amps
288 RPM with 3 times 216 uF 10.5 Amps
299 RPM with NO CAPS 1.2 Amps
299 RPM with 3 times 54 uF 4.5 Amps
392 RPM with 3 times 216 uf 15.0 Amps *
412 RPM with NO CAPS 8.2 Amps
* It is to be noted that our 240 volt motor which draws 7.3 Amps unconnected to a F and P Draws 8.0 Amps here Also our rectifiers start to get hot but the stator does not.
FandPwithPVC
Posted: 09:47am 23 Dec 2007
FURTHER BENCH TESTING OF A 8SP IN STAR ON 24 VOLTS
Hi ALL
200 RPM with 3 times 300 uF just starts putting out
260 RPM with no caps NOTHING
290 RPM with no caps just starts putting out
280 RPM with 3 times 300uf gives 5 Amps @ 50 volts
into 6 /12 volt (48v) car lights and shows 50 volts
416 RPM with no caps puts out 8 Amps @ 29 volts
390 RPM with 3 times 300 uf puts out 15 AMPS @ 29 volts
All For Now Dennis L
adelaide
Posted: 10:40am 23 Dec 2007
cool well done have you noticed any thing bad with more caps or is it better the more u add ?
help to make progres or radio and vitamin b
