Local Time 21:01 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Found a black coloured F@F rotor
brucedownunder2
Posted: 03:01pm 22 Aug 2015
hello , I have come across a black coloured F@P rotor. never seen one of this colour before.
Could anyone out there confirm if it,s different to the old grey coloured types. I can,t access it for a couple weeks and want to know it,s specs,if different from the older types..
Did F&P ever bring out a Neo magnet type rotor??.
Bruce.
Bushboy
DaveP68
Posted: 01:31am 15 Sep 2015
Hi Bruce
These Black rotor caps can only be used on the 36 pole stators not the older versions.
They provide a 40% increase in output power for the same RPM as the strength of the magnets is greater. But the minor down side is they have a higher starting force.
The white arrow head rotor caps are hard to beat on a decogged 36 pole stator.
Hope this info answers you question.
David
brucedownunder2
Posted: 10:55am 15 Sep 2015
Thank You Dave, Would you know if the new stronger magnets are the ,Neo, types?.
Thanks ,Bruce..
Bushboy
Posted: 12:12pm 15 Sep 2015
Hey Bruce
If the black rotor is for the new 36 pole stators, and has stronger magnets, then it would make a great 7 phase conversion on a old 80 or 60 series.
