Local Time 21:01 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Soma wind generator disassembly
gactrx
Posted: 08:56am 09 Mar 2015
Hi, has anyone pulled the slipring out of one of these? I have removed the but when trying to lever out the sliprings and bearings with two levers between the square section housing and the rotating pipe sleeve it doesn't move. Do the sliprings pass though the bearing ok?
Thanks,
gactrx
Posted: 04:19pm 23 Aug 2015
When replacing the swivel pole bearings unsolder and remove the slip ring cables first. Pull the cables out from the hollow shaft. Then press bearing including slip ring assembly off.
