Local Time 03:40 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Wind powered tree pump.
Warpspeed
Posted: 02:15am 12 Sep 2007
Now here is a really off the wall wind power idea....
http://www.igeawagu.com/news/erfindungen/1187227447.html
Cheers,  Tony.
Gill
Posted: 03:32am 12 Sep 2007
Definitely outside the square, but workable(of sorts).
I reckon this man could do something with the hot air and bs in our Parliament House too.
Cheers Gill _Cairns, FNQ
KiwiJohn
Posted: 05:44am 12 Sep 2007
It would be easy enough to take a cable from up your tree and bring it down through a couple of turns around the axle of your F&P with a weight or big spring to return the cable. You would get rather 'peaky' power but better than nothing and easier than most!
Warpspeed
Posted: 05:58am 12 Sep 2007
It might also be a very sneaky way to make a small amount of unobtrusive power in a small suburban back yard, where neighbors or the council would frown upon building a serious wind machine.
Fairly close to the ground, where there are a lot of up wind buildings, the wind will be more gusty, causing more tree movement than in a proper open wind site.
It is a crazy idea, but it may have some stealth application if very fine wire is used.
If I were going to try this, I would prefer a very long spring to weights. Weights have inertia and might tend to snap the wire. Bungee cord would supply a more constant return force. An F&P would be ideal, because it will produce useful ac power when rotated in both directions.
Edited by Warpspeed 2007-09-13
Cheers,  Tony.
petanque don
Posted: 12:43am 14 Sep 2007
I must have unusual trees where I live when the wind blows they tend to bow slightly or significantly and maybe wobble a small amount.
They don’t oscillate much at all.
If someone can source some 10Hz x 1m oscillation Norfolk Island Pine tree seeds I will start a campaign to replace the existing Norfolk Island Pines common in the esplanade and beachside suburbs of Adelaide with this subspecies.
vasi
Posted: 01:35am 14 Sep 2007
I remember this:
[quote]“Mr Attey’s design has considerable advantages over other residential systems that are being developed in other parts of the world,” Mr Carpenter said.
[/quote]
Elvish name: Mablung Miriel
Beyound Arduino Lang
