Local Time 03:39 25 Oct 2026 Privacy Policy
Forum Index : Windmills : homemade windmill
Brewser
Posted: 02:44am 19 Jul 2007
i have a 60 hp 480 v 3 phase fire pump motor i would like to make a windmill out of. what kind of percentage of power in watts will i recieve if it were spinning its full rpm rating on the nameplate.
would i be able to spin the motor with a large enough windmill? will i need some sort of gear reduction to spin the motor faster?
i was thinking of rectifying the ac output and charging large electric fork lift batteries with a stepped down dc current.
davef
Posted: 07:12am 19 Jul 2007
60hp * 748watts/horsepower = 44,880 watts. This is A LOT of power!
Probably about 100 times the power you would get from your typical "backyarder" windmill setup.
