Local Time 21:41 24 Oct 2026 Privacy Policy
Forum Index : Windmills : New to wind power
JKNZ
Posted: 10:39pm 27 May 2014
Hi everyone
My names Jason, I'm new to the whole wind power game and am after a bit of advice.
We have an electric gate that uses 12v batteries and I'm thinking of making a wind generator to keep the battery charged, I've been thinking of using a smart drive motor as described on this site but i"m not sure what I have to put between the generator and the battery.
Any advice would be greatly appreciated
solarwind
Posted: 03:10am 28 May 2014
Hi JKNZ,
That is called a charge controller. Have you already built your turbine and tested it?
If it is only for opening and closing a gate, a simpler solution would be a solar panel, a charge controller and your gate battery.
You don't have success until you've tried it!
JKNZ
Posted: 09:06am 28 May 2014
Thanks, no I haven't built the turbine yet, still just trying to make sure it's worthwhile doing.
We do have a solar panel on there at the moment but where it is, there isn't always a lot of sun, especially in winter and it goes flat over a few weeks but there is a fair amount of wind.
Would I have to have a rectifier as well?
MacGyver
Posted: 09:22am 01 Jun 2014
JKNZ
First off, Welcome to the 4m!
"Would I have to have a rectifier as well?"
That depends on your power generator. If it were an actual "generator" with brushes and a commutator, then the likely answer is no. That kind of rig, like the old VW generators, produces pulsing direct current.
IF, however, you use an alternator to create the electricity, then the answer would be yes. An alternator creates alternating current (strangely enough) and that requires rectification into what I believe is termed flat-wave d.c. IF I'm wrong, I'm sure someone will jump in with a correction.
In either case, be sure your alternator or generator puts out at least about 1.5 volts more than the rated voltage of your storage battery, or it won't charge the battery. I'm currently working on a VAWT project for a farmer friend, who wishes to use a small, ground-level turbine to charge his 12-volt electric fence batteries.
. . . . . Mac
Copeville, Texas
CBSOS
Posted: 12:55am 21 Jun 2014
Hi folks I to am new to this forum and also to wind powered power generation, I have access to lengths of alloy extrusion which would be suitable for wind mill blades, I have thought of constructing a mill for a friend who lives on a bush block subjected to a constant prevailing wind, my thought was a barrel fan spinning on a vertical axle, each blade 8"cord X 1200 long.
I have a F&P smart motor and no wiring explanation, can anyone help me?
Chris
Posted: 05:24am 21 Jun 2014
HiCBSOS,
Firstly welcome to the forum.
Secondly its best to start your own thread with a question, rather than hijack another thread with your question.
As for your VAWT (vertical axle wind turbine) well i wish you luck, as they are almost useless compared to a HAWT.
Perhaps time to re think your design would be my advice.
Pointless advancing to a controller question when a VAWT mill will be lucky to make any usable power, lead alone enough to need a controller for.
Pete.
