Forum Index : Windmills : 25 000 watt homebrew
| solarmike Newbie Joined: 14/11/2005 Location: CanadaPosts: 26 |
I found a transport truck rear differential for $300 and I am going to lock out one of the half axles and make use of the already built in drum brake. The gear ratio is 8:1 and I am going to mount a 50 Hp salient pole synchronous motor to it. I will try different blade lengths to find out how much power I can get out of this beast. The tower is something i must build myself. I am a welder. I am not going to pay $100 000 for a 40Kw machine. I would rather build one. whada ya think? I just sketched this in two minutes to illustrate I am solarmike |
| Chris Senior Member Joined: 12/09/2005 Location: AustraliaPosts: 146 |
I wouldnt use a differential from any car, they have to much resistance for windmill application due to oil and stuff like that. You would be better off making your own gearbox that converts to 90 degrees or mounting your motor directly onto the blades shaft... |
With respect to using a car diff, have a think about the internal oiling. At normal angle, ie in a car, the crown gear sits in a bath of gear oil. This splashes the oil around the casing and lubricates the pinion and spider gears. Oil is also splashed down the axle tubes ( also helped when the car corners ), and into the wheel bearings. When you tip over the diff for your windmill, you may need to add some extra oil, enough for the crown gear to sit in. There may be a problem with oil leaking out the pinion shaft seal too. And you need to make sure some oil makes its way down the axle tube to the wheel bearing. Other than that, it looks good. The old car diff is built pretty strong and your big blade will have no problems turning it. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Storm![]() Regular Member Joined: 12/09/2005 Location: AustraliaPosts: 43 |
Definantly the first thing I thought about when considering using a diff was the pinion seal will leak before to long especially if you put more oil in to keep the oil up to the gears, I was thinking of using a datsun independent diff as they have short shafts, but moved away from the whole idea soon enough. But maybe you can tell us all when you get it working eh? |
